Engine Water Temperature Question
My 95 Z28 with the LT1 used to run its best at lower water temperatures, just off the 160 peg.
I have no experience with the LS1 and am curious about where it performs the best in regards to water temperature.
Thanks in advance for the information/advice.
Rob
I used to be fanatical about coolant temp, but what would happen is I would pull to the line with the coolant below normal, and it turned out the T-stat wasn't open yet. Then at the end of the pass, the temp would be hotter than normal because I made the whole pass with the T-stat closed. Don't do that.
It is good to have all the metals heated and expanded to keep the gaskets intact, but then ice down the intake manifold between rounds and such to keep the IAT as cool as possible.
Al
