Drag Racing Tech
4l60e wiring delete
Old Oct 2, 2016 | 11:35 AM
nj02z's Avatar
Default 4l60e wiring delete
Made the switch to a TH350,now looking to delete the plug.I have all trans wires disconnected from the pcm except one last pink fused wires. Can I just cut this wire out where it runs to the trans plug? I believed it is a keyed ignition source. I hope someone has encountered this.
Old Oct 2, 2016 | 07:47 PM
RENE'S RAGE's Avatar
As long as it doesn't feed anything else hot.
If you traced it from the trans to the pcm and it goes nowhere else your good.
Old Oct 3, 2016 | 04:34 AM
nj02z's Avatar
I just respliced it and eliminated where it went down to the trans. I left the feed in from where it was coming from and going to.I encountered several other spices also while eliminating excess wiring. I am just being very careful before I eliminate.
Old Oct 3, 2016 | 08:20 AM
Yeah, several red and pinks are spliced together.
I believe reds are always hot off the fuse block and pinks are ignition hots.
