Drag Racing Tech
Finally weighed the car
Old Apr 20, 2002 | 09:19 PM
ONYXSS's Avatar
Default Finally weighed the car
Went to a digital scale this week. Weighed 3440 with me in (with some stuff in the car), after this years weight loss. Then made DETAILED calculations, by weighing the parts that differed this year from last. Result was 3547 lbs. Within 3 lbs of my estimate that was challenged so many times by a few guys. I'm happy that my info was accurate (thanks to Nineball for a good starting point). But a little dissapointed that I didn't come in lighter this year.
Either way, my raceweight this year should be right at 3400 lbs once I put the panels and carpet (lightweight, not stock) back in that are out right now for cage install.
<small>[ April 20, 2002, 09:26 PM: Message edited by: ONYXSS ]</small>
Old Apr 20, 2002 | 09:48 PM
Sears's Avatar
!Dial-up Director
Default Re: Finally weighed the car
Those are killer times to be running at that weight! Congrats
Old Apr 20, 2002 | 10:58 PM
JS's Avatar
JS
Wow Dave pretty close to your 3550 guess.
What did u take out Dave or add to the car ot get it down in weight?
Is the 3400lbs with a cage in the car?
That should net u 10's....
JS
<small>[ April 20, 2002, 11:00 PM: Message edited by: JS ]</small>
Old Apr 21, 2002 | 05:33 AM
ONYXSS's Avatar
k-member, dynobatt, !AC (for now), lightweight carpet, hals..........
yes, 3400 should be with cage.
Old Apr 21, 2002 | 08:42 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Damn I'm good! I'm usually pretty good a guessing raceweights, the ONLY car I haven't figured out is ProStockJohn's slightly gutted hardtop Formula weighing in at 3700 lbs vs my fully-loaded Formula with no weight removed weighing in at 3550 lbs.
<img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
I keep telling him that someone hid some lead in his car <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Tony
Old Apr 21, 2002 | 10:51 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
T-Dawg, what is not to believe.
Car was 3400 w/o bone stock.
I go about 190 lbs.
Add cage, iron block, 9", and then subtract AC.
Old Apr 21, 2002 | 09:57 PM
minty's Avatar
but john, Im guessing you also weighed the car with pro stars and slicks and skinnies right?
Old Apr 22, 2002 | 01:17 PM
LS1Tech Co-Founder
STOCK it was 3410 with stock everything at Byron Dragway a few years ago.
Between ditching the complete AC, Prostars front/back, !front swaybar, !air pump, !egr, !backseat and belts, !floormats, !jack and spare, I figured I have removed 100 lbs.
AC 40
swaybar 10
back seat belts 25
floormats 4
jack/spare 35
3410
-100
3310
+190
3490
+75 iron block
+75 8 pt moly cage
+50 moser 9"
3690 lb raceweight
Dave, thanks for weighing your car and posting the results. The fast folks always get questioned.
Old Apr 22, 2002 | 01:37 PM
mattf2's Avatar
Good job Dave!
Maybe that 10 second slip will come quickly!
