Do I have a trans/converter issue?
Is this actually the converter or is 3rd slipping a little? Or is it something else? If a trans issue, would the transgo hd2 kit "fix" it for a little while?
Trans is a 3 year old stock rebuild with 5k miles on it.
Are you commanding that afr at wot and if so what amount of timing are you running at wot with that afr? Also, why size tire are you running. If you would rather pm that information that is fine as well.
I'm running the 3052R MT 26x8.5x15 pro drag radial. 26.4" dia.
Also did you notice a difference going from 3.42 to 3.73 ?
After that day of racing, I bought hp tuners. Found out the car was shifting at 6100 so I played around and got it to shift at 6500 and picked up 1 mph in the 1/8:
As for converter efficiency, I assume I was coming up with high slip % because 1- going off factory tach and video 2- using trap speed which is an average. With hp tuners, the % calculates much better using logs.
3rd gear also holds fine on 100 and 150 shots:
3.42 to 3.73 tightened up the take off feel making for a better around town experience. I can't say that I notice a difference at the track.
