Double check my ratios and the logic behind it
-Honda S2000 RWD/2600lbs
-5.3 LM7 (ARP Studs, LJMS S2 Cam, BTR Valvetrain, LS9 Gaskets, Rings Gapped, Hone, basic stuff)
-S475
-Running on Ethanol goal is to make 800/800
-8.50 10pt cage
-Stock TH400 (eventually will build it but want the car running first)
-4 Link Rear/Shortened 9" Housing/Trac-Loc/31 Spline
-15x12 Weld Alumastars w/28x10.5W MT Bias slick
-15x4.5 Weld Alumastar 26x7.50 Bias ply sportsman skinnies
I am trying to figure out my rear end ratio and want to make sure my logic is sound.
28" Tall Tire
x
Final Gear TH400 1.00:1
x
6000/6250/6500rpm limiter
x
175mph trap for mid 8`s
2.86/2.98/3.10 respectively for the limiter changes. What one should I go with? Also too the car will see a fair amount of street driving but don't want to sacrifice any 1/4 mile times for street comfort.
Thanks for the help in advance all
Good luck with not sacrificing street comfort in this car. I just touched 9s with irs in mine and its a total chore to drive slow
