front spring weight recomendation
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Your 60' times are already impressive considering what you have on the front. Choosing the correct spring rates really is determined on what you are doing with the vehicle as much as it is the vehicles weight.
A street driven vehicle you will want to run a heavier spring than a vehicle that is drag race only. The nice thing about springs is they are not crazy expensive if you want to try a couple different rates.
A street driven vehicle you will want to run a heavier spring than a vehicle that is drag race only. The nice thing about springs is they are not crazy expensive if you want to try a couple different rates.[/QUOT
The plan is a diet this winter. Would there even be a real benefit to swapping if the car is dead hooking? I'm talking I can throw what ever I want at it with no progressive anywhere the car goes. My concern is what will happen if I pull a bunch of weight. I can pull 150 lbs easily. Won't be out the front. Swapping to kirkeys and eliminating cat back for dumps. Don't want to delete AC/heat at this point.
Still 300s? Some street time.
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
You can get close but some are past the point of doing things to be close.
.... Would 275's fit on stock style shocks?
