Drag Racing Tech
Not sure on next suspension mod
Old Dec 20, 2016 | 07:29 PM
jlrz28's Avatar
10 Second Fun Car
Default Not sure on next suspension mod
Would like to do something more to the suspension, currently here is what is done. Would like to put parts where its needed. Looking at getting rid of the poly bushings and going to rod end lcas. Any suggestions or what am I missing? Thanks
Front
Viking DA shocks with 300lb springs
removed the sway bar
Mid Car
Subframe connectors
Rear
BMR adjustable torque arm, still in stock location
BMR poly LCAS
BMR poly panhard bar
Spohn drag bar
Qa1 SA shocks
Old Dec 20, 2016 | 10:44 PM
Firebirdmuscle's Avatar
MWC k member would save a good amount of weight off the front
Old Dec 20, 2016 | 11:04 PM
ElkySS's Avatar
Torque arm relocation would be a good idea. I'd be scared running those times with it still bolted to the trans.
Old Dec 21, 2016 | 01:47 PM
jhshnh's Avatar
Agreed.
Old Dec 21, 2016 | 06:13 PM
JL ws-6's Avatar
Race your car!
I also would suggest getting the tq arm off the transmission. bad design from the factory there.
After that, start looking for a good front end package. Several out there to choose from, just get something that doesn't have adjustment "slots" for the lower control arms or you will fight keeping it aligned forever.... need a hole and hole only. Or if you do end up with the slotted style, get some steel washers 3/16 thick made up and before you align it, take all the paint/powder off where the control arms bolt in... put the washers in so after alignment you can weld them to the K member and never have to worry about the alignment going to hell cause a bolt slid in the slot.
Old Dec 22, 2016 | 09:45 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
As stated above, I would do either a relocation crossmember or a short style torque arm, such as the TA012 or TPU001. You will want the torque arm off that tailshaft either way. The next step would be taking weight off the front end in the form of a tubular k member and a-arms. For information on just how much you can save off the front you can look here:
https://ls1tech.com/forums/suspensio...nceptions.html
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Dec 22, 2016 | 10:43 AM
jlrz28's Avatar
10 Second Fun Car
I have one more adjustment hole down on the lca mount to the rear end. I finished pulling the dash and removing the ac and duct work. Just got my vfn hood installed. So between those two I hope to have shed some weight off the front. I will look into getting the torque arm off the trans also. I always look at the k members but just some things about them bother me compared to the oem piece.
Old Dec 22, 2016 | 10:56 AM
BMR Sales2's Avatar
Once you use a tubular K, you won't want to go back. The weight savings is a big plus, but the room is opens up to work around is huge as well
__________________
Glenn ***
Sales Tech
813.986.9302
Old Dec 22, 2016 | 11:52 AM
gesto's Avatar
Do you know which vendors offer these without adjustment slots? Thanks!
Old Dec 22, 2016 | 10:40 PM
JL ws-6's Avatar
Race your car!
I know the Burkhart one does not have slots. I have this one personally. I believe the Midwest one, or at least one version of his also does not have slots, I can not speak for the others if they offer one without the slots. I have however welded the washers I speak of on Spohn, Bmr and Pa k members over the years for people.
Old Dec 23, 2016 | 02:34 AM
SteenH's Avatar
Sorry for hopping in.. What's the consensus on slot vs hole K-member with stock A arms? Thanks in advance
Old Dec 23, 2016 | 06:58 AM
JL ws-6's Avatar
Race your car!
Can't use a stock a arm with any other than a slot, it's the only way to have adjustment. I would never go to the trouble of swapping the k without doing the a arms too. My .02
Old Dec 23, 2016 | 08:38 AM
MidwestChassis2's Avatar
Nothing wrong with a good tubular K-Member. They have been around on street driven vehicle for a very long time.
Old Dec 23, 2016 | 08:43 AM
We offer a K-member with holes for our two piece a-arms and slotted for our one piece a-arms or for stock a-arms. I do want to add I have never had a customer complain about keeping a slotted K-member in alignment.
With any aftermarket part from any manufacturer it is a good practice to check bolts on a regular basis. This is something that is not discussed enough and over looked.
Old Dec 23, 2016 | 08:47 AM
You are not going to get any alignment with stock a-arms and a holes K-member. Our holes K-Member is designed for our two piece a-arm how ever it is also designed for a narrower wheel not a wider stock wheel.
Old Dec 23, 2016 | 08:50 AM
Just because it is there doesn't always mean you will need it, to much angle up towards the body could make it worse for you. Of course this is why one should test, test, and do more testing keep track of what the changes do.
Sadly track conditions are never the same and what worked one day as far as settings may not work the next time out.
Old Dec 23, 2016 | 12:29 PM
Heyfred's Avatar
Scale and corner balance the car.
Old Dec 23, 2016 | 04:04 PM
JL ws-6's Avatar
Race your car!
Fwiw the issues with skits I've seen is the washers slipping on the powder coat. Usually anpothole or wheelstand that does it.
Steel washers welded on stops all that forever once a good alignment is done
Old Dec 23, 2016 | 09:42 PM
01ssreda4's Avatar
No issues on my slotted k mmber though I dont drive the car much. One thing I did do was go back and re-tighten the arm bolts tighter then what the alignment guy did, heard that was good insurance.
Old Dec 24, 2016 | 07:58 AM
JL ws-6's Avatar
Race your car!
It absolutely is.
Long as you don't 12 o-clock the car, or hit any pot holes you'll likely be ok. Most of the guys I've had to weld up have done one or the other.
