First time at the track with the new setup....look inside...
Great Lakes Dragaway is where I raced at tonight...got about 5 passes in...
I was getting used to how to do a burnout with the TH400, finally got it perfect after a few times, the left tire even fully wet would grab when I shifted into 2nd on the burnout and then the rim spun inside the tire...
All other 60's of the night were in the mid 1.8's... <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
Best I could get out of it was
R/T = .345
60 = 1.75
330 = 5.070
1/8 = 7.826
MPH = 89.71
1000 = 10.217
1/4 = 12.254
MPH = 110.4
Best MPH of the night was 111.97
That was the best ET..
The suspension I am running currently all around is the bilstein road racing shocks with eibach lowering springs...also running the nice heavy chrome firehawk wheels up in front too, still got the sway bar, etc... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I didn't use the T-brake at all (not worth it) I footed stalled it a bunch of different ways..
The track was hooking for **** and no matter what kind of burnout I did they still spun?
The tire that was grabbing and the rim spinning inside is now completely flat... <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
ET DRAG time??
I will most likely go to US41 this weekend and get some real times on the car..
The only weight reduction done to the car is...
Backseats
Spare/Jack
Passanger Seat (track only)
Rear speakers (track only)
Few other details, the car has a 12-bolt w/3.73's..
<small>[ April 30, 2002, 11:38 PM: Message edited by: BIGBOS ]</small>
mph seems really low if you spun.
opening week i went 12.1@112 (1.69). i pretty much hooked but left easy.
i dont get how your wheel spun around the tire? how much psi were you running, like 2 pounds?
Like I said, the left one is flat right now, I hope it can be repaired... <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
I'm sure I can crack off some 11 second passes how it sits RIGHT now at 41
<small>[ May 01, 2002, 08:54 AM: Message edited by: BradWS6 ]</small>
Mine was good for 1.3's footbraking with the old motor. I think I may need more stall when the new motor goes in, though...
your car is not setup for dragracing in all reality right now..i could tell that when you got on it when you took for a ride in march.
its not like you're gonna be racing around the turns anyway with that trans and gear, so may as well do what you need to do to get the weight transfer down.
ET is a great start, like what i'm seeing with that trans if you catch my drift <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> But like was mentioned, I think the MPH is a bit low, did you get any ATap logs or anything during your passes?
Sean
A.R.T 98 Z28-Silver
2002 Durango SLT-Silver
George I am running the identical converter that you were running, I am selling it because I want to spray, I think its too big... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
John, I was very suprised to run into you, what are the chances of that happening.. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I got to see if I can get my ET street repaired and then I am going to go to 41 this weekend and try to get 1.6 60's off of this suspension, if I can do that then I can only imagine what hals would do.. <img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" />
Do you have heads yet or just a cam?
Have fun.
John <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
I think that one tire has a bad seal or a hole in it.
I'd air it up and check for a hole.
My 26x11.5x15 ET Streets get run at 15ps, and lose about 2-3 lbs of air per month.
My street tires are those MH's, and loses more air than the other no idea why.
I think you have 11.9's for sure, maybe down to a 11.7 if you do what Brad suggests.
I went 12.2 on DR's with H/C/I/verter and 11.7 on ET Streets two years ago.
You definitely have 11's with traction good job!
Chris
It sounds like you need to practice your burnouts and do a couple of mods and you will see some 11.9's or better.
I think Pris was cutting mid 1.6's on Nittos and she ran 12.2 @ 110.5 with very minimal mods - but she does one hell of a burnout! <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
<strong>
I think Pris was cutting mid 1.6's on Nittos and she ran 12.2 @ 110.5 with very minimal mods - but she does one hell of a burnout! <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"><img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" /> who me?? <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
That's true, but last night at GLD I could only muster 1.7X-1.8X 60's on the Nitto's. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> I had to really ease into it off the line or I would spin.
BOS, just a few more tweaks to your car and you're in the 11's easy.
