Reducing rolling resistance?
If I moved from a 28" tire to a 29" would I slow down in the 1/8?
Sorry didn't mean to hijack...
Plz chime in if anyone has solid proof as I to would like to gain a solid tenth or two
I was thinking of changing up my wheel/tire setup to a lighter setup. After Doing a bunch of research I've come to the conclusion they don't make a big difference in 1/4 times like people think. Hot rod magazine or car craft (can't remember) did a wheel weight 1/4 test and the results were surprising. If I remember correctly it was less then a tenth.
Maybe for road racing that involves braking, etc it will help overall performance.
Of course, like all internet myths, it has spread so much that it is currently a fact. I actually saw one guy claim it was a 10X difference. The power of the interwebs......
Al
Al
Weight on the rear end housing.... doesn't care what the suspension doesnits holding the rear tires on the track regardless....... food for thought.
that is very interesting to me...any pics or links to ways this is being done ? is there a good/safe low budget DIY type way to do this ?
I took my bolt on A4 car to the track once on a street night and traction was difficult to find with people running treaded tires through the water , I started out with 12.5's on 1.9 60 foots , removed front sway and got into 1.8's then track got worse and went 1.9/2.0's threw my iron floor jack and toolbox that weighed about 75# in the trunkwell ended up with 12.1 PB with a good 150# over stock car weight and that was with a fuel pump on its way out missing over 5500 . Without the added weight in the back I never would have gotten bottom 12's
edit: your making me think about bigger rear ends having a benefit to factor in the whole equation s60/9" etc... beyond the added losses from turning beefier internals and overall weight if it helps keep tires planted it may not all be negative with the added weight...
Sometimes thinking out of the box will get results.... if your car is light for a class and you dont wanna disturb it.... this works very very well contrary to what most will tell you.
