Drag Racing Tech
New guy, same questions
Old Mar 2, 2017 | 01:39 PM
OxTheGreat's Avatar
Default New guy, same questions
Good day all, ive been stalking LS1tech for about 5 years off and on, and pretty constantly the past year since ive been itching to build a junk yard 5.3 LM7 drag only door car. As everyone else (mostly) im working around a budget. But my OT pays.for it so im able to work more to get more parts. So far pur plan is pretty straight forward (i think)
98-01 f body
LM7 5.3 junk yard engine
Summit racing 5.3L block to hot swap parts
Keep 862 heads for now
Full rebuild and gap rings 25 thousamdths
​​​​​​80+lbs injectors
Comp cam turbo cam
Twin CXracing 76mm turbos
Proglide 1.80 with transbrake
Thats the basic concept of the build, small engine, big turbos and shoot for some numbers. I know suspension and fuel system is required but haven't here's gotten there yet. We are building it for 1/8th mile with largest goal of mid-low 5 et. I doubt the 5.3 will get me there.
But here is where i get lost in the sauce.
We are trying to build a big potential engine that can slowly be pushed. Looking to get the above set up to est 500-600hp since the biggest hp ive driven was a 468hp car. Once we get the feel be able to bump it up to 700-800 then repeat. Am i going to be able to do that without hurting engine? I dont know enough about fuel injectors to know if running low psi will hurt me.
Same with rear end gearing. Do i gear the car for current HP raiting or do i gear it with gears needed for the end results? (That sounded off in my head) all the calculators say something like 4.58 gears for 5 sec 1/8th mile et. With a 3400 lbs car at 800hp. How will that effect me when low tuned to 500-600
I know adding 317 heads will drop cr to 8.5:1. But since i am a drag only car, is that ok? Im lookimg for better flowing heads and larger valves than 862s.
Suggestions are welcome
Thanks in advance
Old Mar 2, 2017 | 05:03 PM
01ssreda4's Avatar
Lots of info in the boosted section. Just had a buddy push a 4.8 into the 20+ psi range before it finally let go. It was a bone stock engine.
Old Mar 2, 2017 | 08:23 PM
murphinator's Avatar
several junkyard 4.8's on big single turbo's out there running single digits in the 1/4 so it should be possible to go 5's in the 1/8. usually big turbo builds don't go very deep on gear because the torque will easily overcome gearing then if you get a chance to run 1/4 you mays till have the gear to finish....
Old Mar 2, 2017 | 08:32 PM
OxTheGreat's Avatar
Ive researched big single vs twins and results are confusing. I want 1000hp with room for a little more. I know a 5.3 wont get me to a 1000 but its my first build so im ok with getting close and learning. Do i invest in a huge 80mm+ turbo or .....?
Old Mar 3, 2017 | 06:49 AM
a05c's Avatar
If its a race only deal, i'd put it on Q16 with 12.5-13:1 static, a good trans and converter behind it and it'll go fast.
Old Mar 3, 2017 | 06:55 AM
OxTheGreat's Avatar
Q16 at 12.5-13.1:1 compression? With boost? My brain just glitched thinking about that.....i was looking at E85 or E98
Old Mar 3, 2017 | 08:43 AM
a05c's Avatar
The engine that's in Ray's car (the car I work on) (5.3 Casting, ERL Superdeck)is in that range, and at 25ish psi of boost makes enough power to go 194mph in the 1/4. That's on gas also (Q16).
