Setting Goals...then the road to accomplishing them????
So how do you guys get to where you want to be. I know as most people do, that it's all in the combination. But how do you go about deciding what that combination should be. Basically, I'm asking in which order do you go about picking parts to get you to your goal?
Cam first? Converter first? Gearing/Tire size first?
For me, i know I need a pretty stout cam. One that's gonna be in the upper rpm range. So then do I match the converter to that rpm range? but then if i got that taken care of, how do you go about picking gears and then tires? I know it'd be an E.T. Drag or a Hoosier slick. but width? dimension?
Obviously the first small goal to accomplish is to get all the bolt ons taken care of. That step is in process. I am aiming for a goal of high 11.3's-11.5's for a BOLT-ON car. Then maybe with some more weight reduction and the cam, hopefully i'll hit the number.
So any advice on how to go about picking combinations? I'm not really looking for cam specs or converter choices, just general help in the process I should take. Thanks!
Chris
they aren't all machined exactly the same as we all know and some are better than others....thats why so many pick up so much hp with heads/cam and others dont
for instance.....roy. i believe his heads from the factory will flow great numbers and he wouldn't see a huge gain from a heads/cam
So just hope you have a good pair of heads, take weight out of the car, put in a good gear/tire/converter and all the bolt ons and pray to the hp gods
thats a start. its the gears/tire height that you should play with
I have a goal to run 10's at 3500lbs w/a stock short block and on ALL motor.I'm close as I've gone 11.17@120.With more tweeking and some good fall air I hope to accomplish this goal.
Will see and good luck w/your goals people
JS
<small>[ May 08, 2002, 10:21 PM: Message edited by: JS ]</small>
would i be better off going w/ the 114LSA because of needing to run up higher in the RPM band?
Chris
PS-moderators, if this gets to the point it should be in internal engine, please move it. thanks.
<strong>thats the cam i was going to suggest the pig cam 226 .591 112ls u gotta turn the rpm though</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">yeah...thats what the 4.10's are for <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
GTP has a 226/236 514/514 114 also. it make pretty good power.
