two step and trans brake
If you turn the 2 step on and the transbrake and your RPMs are at 3000 when you mat the gas then your 2 step is set for 3000.
You will be fine flooring it when the top bulb comes on; you'll only be against the brake for ~1 second.
Hope this helps you out.
You should be against the converter and the RPMS that you are limited to there should be an indicator of your converter's stall speed.
I have a th400 with a brake, but don't use the brake right now. I have the MSD 2step and have a master switch that goes to a Reed switch (think security contact on a door in a house) that is on the brake pedal. When the master is turned on and I press the brake pedal enough to get the magnet close to the switch it activates the 2step.
Let me know if you want more details.
