Well, that was a disappointment!
I went on drag times and your tracks elevation is 628 , your slip is cutoff so I cant see date but assuming you raced the night before you posted about it the closest data to 10:45 available is 10:53pm temp was 64.9 humidity 81% and baro was 29.77 giving a da of 1560 not great no terrible.
Your biggest problem on your slip is the 60 foot , if you get some dr's on it and trim that even into the 1.8's your times will get very low in the 13's , lighter wheels , dr's, and better racing weather and you will be flirting with that 12.9 you were hoping for. Your mods should produce 12.6-12.9 results on a sticky tire IMO especially with an 01 car it should have the LS6 Intake manifold on it. very similar in mods to one of my automatic cars that went 12.1 @112 in better weather with a 3600 stall , after tires stall would be your best investment it will knock off at least 1/2 second for you.
The first is that tire and wheel combo. A 19 with a standard street tire will be very difficult to get much promising performance out of. The next I see is the lowering spring. These are causing 2 issues. The first being the lack of rate. Eibach springs have very soft rates and do not tend to put much pressure on the tires for launching. The second being that the control arms being in the stock location, they are now at a downward angle towards the chassis which is also unloading the tire. A relocation bracket and a decent tire will make a huge difference in your 60' times and getting the car quicker. A better spring wouldn't hurt either
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
also, I've read where people use the spare tire rim and different tires for the front. Is it worth it?
I'll only go to the track once a month and I'll only drive it 75 miles a week but I'll ride these current wheels until I want to go to the track.
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
