Fbody heads up racing
The MHRA class I have been paying attention to is Factory stock. I am watching these guys take cars with barely any mods into times where a car like that shouldn't be.....or maybe should??? I want to answer back for the lack of heads up racing in the Fbody community. I was wondering if any of you guys would be interested in a few different budget minded heads up racing classes.
I know next I am going to get the "but in bracket it's all equal and everyone has a fair chance". My answer to that is in a class like the ones I am thinking of it won't take much to be competitive and "equal". Since it is a budget minded class you won't go bankrupt trying to build a class car either. once you hit the limits of mods it all comes down to driver, much like bracket racing. Major difference is the excitement. being 3/4s through the quarter and being nose to nose with someone knowing anything can happen can really get your blood pumping. You can go all out without the fear of breaking out. It's true racing at it's fullest.
I have been working on some brief outlines for some rules to give you guys a general idea as for what to expect so I can get some good honest opinions. Mind you, these are a very brief general outline for 3rd gens and LS1 cars.
1982-1992
Stock L98 bottom end
Stock cam
Milled L98 heads allowed
Head porting not allowed
Aluminum L98 Corvette heads allowed for people running TPI set ups
Any TPI set ups are allowed
Dual plane carb intakes allowed
Roller rockers allowed
Must have full exhaust (ie: headers and mufflers)
Auto or Manual transmissions are allowed
No transbrakes
No stall converters above 4k rpms
Battery relocation allowed
No power adders
Must have all stock body panels
Fiberglass hoods are allowed
minimum 3000lbs race weight w/o driver (some weight restrictions apply)
1987-2002
Stock 02 spec Fbody LS1 engine
Ported throtle body allowed
3.73 MAX rear eng ratio
Stock tranny required
up to 1k rpm higher than stock converters maximum
no power adder
no transbrake
3350 minimum race weight (some weight restrictions apply)
Must use stock injectors
must have full exhaust
ALL CARS
Must have a driveshaft safety loop
Run on a D.O.T. approved tire
run a stock style suspension
be fully street opperational (exhaust, lights, signals, etc etc)
Run stock glass
Check that stuff out! Welcome to the board.
Stick around, we can make this happen!
XJOSHX....one quick suggestion. Keep in mind how a rule is be to be teched when thinking about rules. Example....how do you tech a stall converter for its stall speed? Pretty hard to do.
OR
Buy a mustang and really race.
