Drag Racing Tech
Drag race tune
Old Apr 4, 2017 | 05:30 PM
nj02z's Avatar
Default Drag race tune
How much timing can you safely pull at wot trying to slow a LS1 down? I tried pulling 9* without much affect( .15 et.) I am not sure how much I can keep going.
Old Apr 5, 2017 | 07:40 AM
conexion914's Avatar
How much are you trying to slow it down?
Using a 4L60E? What if you try to lower the shift points?
Old Apr 5, 2017 | 07:45 AM
dw456post's Avatar
Shift at 4000 rpm
Old Apr 5, 2017 | 07:57 AM
nj02z's Avatar
Th350 5000 converter.I would likr to run 11.50 index.Just curious how far people have cut timing back.I went 11.07 at 18.5*.I was told kerp cutting it back.I can msybe shift at 5500 but it comes fast.
Old Apr 5, 2017 | 08:11 AM
a05c's Avatar
Why not lift....
Old Apr 5, 2017 | 08:23 AM
nj02z's Avatar
Originally Posted by a05c
Why not lift....
I could until the good bracket racers catch on.i
Old Apr 5, 2017 | 08:27 AM
murphinator's Avatar
That is one negative of getting away from the computer trans you cant make it short shift...you can definitely cut timing back several more degrees. you could also try richening it up or try restricting airflow ( keep tb from opening fully).
I haven't been a bracket racer so don't know the full implications but deep stage should slow it a bit since shallow makes them quicker...
Old Apr 5, 2017 | 08:45 AM
a05c's Avatar
Which is why I can't watch bracket/index racing.
Just back out of the throttle, We use timing to slow wheel speed down and take out way more timing than you do. When it starts to pull the timing out, you can hear it sound like it's laying over and falling on its face. Which you can then see on the G-meter and in the driveshaft trace.
Albeit, we make probably triple the power you do. But killing timing takes enough power out of it to get it to calm down and re-stick the tire. Obviously if its that far out of shape/out of the groove he'll abort like he should but you get the idea.
Old Apr 5, 2017 | 08:55 AM
nj02z's Avatar
So it would be safe to pull more timing?Thanks for the input.
Old Apr 5, 2017 | 07:43 PM
ironmanLS1's Avatar
Mechanical throttle stop on the throttle body or an adjustable stop under the gas pedal. Something that will give you some adjustment to close in on the index.
Old Apr 6, 2017 | 06:38 AM
oh, yeah. I've read about people putting a bolt through the gas pedal and you can make it adjustable so that you're not running wide open.
You could also toy around with getting out of the throttle for a specified amount of time after high gear and then get back in it to kill time.
Old Apr 6, 2017 | 08:40 AM
01ssreda4's Avatar
Throttle stop is what I would do. I have no experience but it seems like a quick and effective solution.
Old Apr 6, 2017 | 12:56 PM
nj02z's Avatar
I do have a stop and ran 76% throttle and -9 * timing and went 11.07.I would like to attack it with timing but not sure how much I could pull from initial 28*.
Old Apr 9, 2017 | 02:46 PM
ddnspider's Avatar
You need to be careful with the throttle stop as the computer needs to see a minimum throttle amount to go to the WOT tables in the tune. I'd drop the shift rpm, let first shift to 2nd at something low and then keep dripping the timing. Don't make it unnecessarily rich, that just kills plugs and wastes gas. Otherwise add some weight to the car.
Old Apr 9, 2017 | 07:16 PM
he has a turbo 350 so he cant adjust shift rpm's in the pcm
Old Apr 9, 2017 | 07:46 PM
ddnspider's Avatar
but he can adjust when it shifts period either by weights or manually ifs a manual valvebody. The point is your spark and commanded air fuel is different when you go WOT, so if you keep restrictions the throttle you may end up hurting something.
Old Apr 10, 2017 | 04:40 AM
nj02z's Avatar
Correct.I went back to 100% and pulled -12* shifted at 6000 rpm and still went between 10.99 /11.02.The converter is flashing to 5020 so I can't shift much sooner. For now I am switching classes as our points series has started and it did not slow down as expected. New class limit 9.00 haha. Something to shoot for NOT!
Old Apr 26, 2017 | 06:30 PM
rpturbo's Avatar
Why didn't you just put a restrictor plate in before or after the TB?
Old Apr 26, 2017 | 07:47 PM
nj02z's Avatar
I did not have enough time to retune the car as our points series started. I could of kept cutting back on throttle position but I needed to make sure it would still go into power enrichment. I was hoping to kill it with timing but did not workout as easy as expected.
Old Apr 27, 2017 | 08:10 AM
01ssreda4's Avatar
Heh, stock engines have a 5k rpm delay for power enrichment. If you were implying that something catastrophic would happen by not reaching an x 1.15 fueling ratio, you'd be dead wrong. Running stoich at WOT wont cause engine damage, it may not make the most power, but wont hurt anything.
