Drag Racing Tech
Drag race tune
Old Apr 27, 2017 | 08:17 AM
fst100's Avatar
soa re you currently running 18* of timing or lower? you mentioned max timing originally was 28* correct? could try and run 14*. i don't know if that low would exhaust the danger zone of high EGT or not. stock timing for LS1 i thought was 16-17*?
Old Apr 27, 2017 | 09:46 AM
ddnspider's Avatar
Originally Posted by 01ssreda4
Heh, stock engines have a 5k rpm delay for power enrichment. If you were implying that something catastrophic would happen by not reaching an x 1.15 fueling ratio, you'd be dead wrong. Running stoich at WOT wont cause engine damage, it may not make the most power, but wont hurt anything.
I believe the 5k delay is only on trucks, not on fbodys, havent seen the thread for awhile so forget what hes got. The concern is the opposite, if power enrichment doesnt kick in it would go lean not rich.
Old Apr 27, 2017 | 02:23 PM
nj02z's Avatar
So what you are saying you would make a full 1/4 pass at 14.6? .It takes more than rpm to trigger pe but I will assume you know that.
Old Apr 27, 2017 | 02:26 PM
nj02z's Avatar
I am tuned at 28* and pulled -14* afr correction.I did not want to go farther in fear of burning an exhaust valve.
Old Apr 27, 2017 | 02:31 PM
fst100's Avatar
any idea on what the turbo'd guys are running regarding timing and boost? the heat generated from the turbo would be way higher than N/A setup if they're running around 12-16* timing in their setup I would think.
Old Apr 27, 2017 | 03:34 PM
nj02z's Avatar
Not sure.. I did not get the results I wanted quickly so I switched classes. I just did not have enough time to keep trying. Someone told me I could pull 18* but like I said,I just ran out of time. I was also told if I kept cutting back on throttle position and I did not meet the map value I would not go into pe.I could of changed the value but everything was working good so I left it alone.
Old Apr 27, 2017 | 06:50 PM
01ssreda4's Avatar
I widebanded my 6.0 and it was happy as all get out running around at 15.0 Even when it hit PE it was only dropping to 14.0s. These older computers arent the best thing in the world. Just checked a stock 02 Camaro tune and PE rpm delay was 5500 rpm. Delay MS is set to 0 so that may counteract the rpm figure. I have little experience tuning with stock tunes, I generally change them before the first drive. Regardless, 14-15 range on a non-boosted application will be a non-issue other then power may be down a tad.
Old Apr 29, 2017 | 02:03 PM
Firebirdmuscle's Avatar
Hey nj, I was running Into this issue as well. What about just lowering your shift rpm since removing timing isn't working for you. If your flashing to 5k and you think 5500 may be to fast, maybe 57/5800. Worth a shot anyhow. This is working for me for now.
And you are verifying that it is actually pulling the amount of timing out that you want on the log?
Old Apr 30, 2017 | 05:24 AM
nj02z's Avatar
Yes I logged the car 14* entire run. I tried 5900.The most I slowed it down to was 11.10.I am going to make a new shifter plate and go from 1 to 3 and see what that does.
Old Apr 30, 2017 | 08:14 AM
ddnspider's Avatar
just to be sure, have you logged all this stuff and can confirm you're at 14 degrees and shifting at 5900 or whatever it is? At 14 degrees the car should be a dog so going 11.1 is hard to believe unless the car weighs 2000lbs.
Old May 1, 2017 | 12:55 AM
snakecharmer1348's Avatar
On bad tracks, I've left with as little as 7* total timing ramping back on over a second.
Old May 1, 2017 | 04:42 AM
  #32
nj02z's Avatar
Yes logged, I had -14* in the afr correction table from 4500 and up. The shifting is done with a shift light.
Old May 1, 2017 | 04:43 AM
  #33
nj02z's Avatar
Stock computer?
Old May 1, 2017 | 07:21 AM
  #34
ddnspider's Avatar
but what was the total ignition advance in the log?
Old May 2, 2017 | 02:13 AM
  #35
Stock computer?
Holley EFI
Old May 2, 2017 | 04:36 AM
  #36
nj02z's Avatar
14.5* entire pass
Old May 2, 2017 | 05:52 AM
  #37
fst100's Avatar
could prolly add something to block the gas pedal from going al the way to 100% throttle if you cant adjust the throttle cable on the throttle body :-p
