Drag Racing Tech
Catch can leaking under pressure
Old May 6, 2017 | 09:33 PM
Rossie's Avatar
Default Catch can leaking under pressure
I drive a drag car that is turbo charged. I have noticed after each run, coolant is leaking from my catch can. This weekend it was so bad i changed the tank for a new one, same result. The coolant seems to come from everywhere on the can. Do need to pressure test, a new cap, any help would be great because if i leak on the track i am dq straight away.
Old May 7, 2017 | 04:33 AM
Doug G's Avatar
Sounds like pressure is getting into the coolant....yes, leak down and pressure tests needed.
Old May 9, 2017 | 04:13 AM
JL ws-6's Avatar
Race your car!
Head gaskets are done. After you fix that put a 20 lb radiator cap on
