How much does tire size affect trap speed?
25.5" Vs. 28" is about a 200-300rpm +/- difference....but the rolling resistance and inertia to get rolling.....could be equal mph, but better ET since you're not on the limiter.
Can you borrow a pair for a test ?
Example:
148 x 3.73 x 1 x 336 ÷ 28 = 6624.48 RPM
If it is an unlocked automatic, then multiply your final answer by estimated torque converter slip and add that to the RPM
Example: 6624.48 x .06(6%)= 397.4688.
6624.48+397.4688=7021.9488 or 7022 RPM.
Well I put 28s on. Used to rev 3200@80mph now it's down to 2700. The nittos looked better, but the m&h racemasters hook way better and I should be able to go thru traps in 3rd @peak torque
Look weird?
If someone sees a significant gain in trap speed from just a tire diameter change, then the prior gearing/tire combo was inadequate.
Al
