Which DOT tire for max traction on a 15x7.5 Convo Pro?
I'm currently running some old 26x8.5x15 ET Drags. They seem to work good but I want to get a DOT tire next. I'm leaning toward the 275-50-15 BFG DR's. Would these hook as good as the Hoosier QTP's (26x9x15 I think)? <img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" />
<small>[ May 15, 2002, 09:43 AM: Message edited by: jswhite ]</small>
Mostly the best tire will be a Mickey Thompson or Hossier Slick. I am not knowledgeable enought recommend tire size at the time. I always call Summit Racing and get assistance from the technical section. I hope this helps and maybe someone else can add to this. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
You want to know on the best DOT tire right? Best out there would be IMO ET Streets. With a Conv Pro 15x7.5 the 26x10.5x15 should fit. It will be tight but should work. The BFG DR is a good tire, but no where close to the ET Street. The other question would be: are you going to be driving on the street with these tires? ET Streets are not much of a street tire, but hell at the track; BFG are very good at the track, but not good if it rains; Nittos are ok at the track and street.
Your choice. You need to deide what you are going to use them for.
David
David
Hoosier makes a few DOT's for this wheel size...Both the 26x9.5x15 and the 27x10.5x15 Quick Time Pro will work well.
LS1Tech Co-Founder
Drag radials will not hook as good as the other tires mentioned here.
I'd say that a tire that is truly about 9" wide will fit best and will not cup.
