Torque Converter/Rear Gear
The car would 60ft from 1.38-1.41 with pretty consistent 6.10 ET but had a best trap speed of 119 mph and a few 115-116mph runs. I'm just thinking that with that speed if the car will 60ft it should be easily in the 5s. I was leaving off the transbrake and tried different launch rpms from 3k-5k and didn't really change anything. Traction is not an issue because I'm running 32x14.5w.
I should add that the car had 60ft times of 1.26-1.28 with previous owner with a hydraulic roller 408 that should have made less power than my engine so I am relatively confident the converter is some of my issue. If the converter needs to be tuned to whole setup and if it is going to give me a better ET then I would rather do gears first and not pull converter twice.
I'm very new to drag racing and am just not sure what the gear change will do.
if you only ran 1/8th then gear for that .
