Drag Racing Tech
Starter options for 13:1 Compression
Old May 31, 2017 | 07:58 AM
racer442olds's Avatar
Default Starter options for 13:1 Compression
Trying not to break the bank, does any one have experience with the starters that say 11:1 compression on a higher compression engine? really not trying to spend 300+ bucks for a starter as this build is way over budget
Old May 31, 2017 | 09:55 AM
blk00ss's Avatar
My stock starter turns my 12:1 over just fine. I'm sure 13:1 wouldn't be a problem either.
Old May 31, 2017 | 10:03 AM
Are they relatively small? My swap has some room, but my donor engine didnt have a starter.
Old May 31, 2017 | 10:36 AM
a05c's Avatar
Stock over 12:1 on 16v system. Cranking timing map can help it starting with high compression.
Old May 31, 2017 | 03:54 PM
Nathaninwa's Avatar
And usually a high compression motor has a lot of overlap to cranking compression might not be as high as you would think. On that note, I tried a powermaster on my 12.5-1 motor and after the solenoid failing three times, went to the the stock one with much better success
Old Jun 1, 2017 | 02:38 AM
Blown06's Avatar
8 Second Truck Club
Over lap has nothing to do with it. The location of the intake valve closing point ABDC is what you need to be referring to.
