hook help
How much burnout are you doing. For me, those tires liked a decent first burnout and every other pass just clean the tire off. No John Force showboating required.
Don't confuse these tires with street tires, they are not, different compound, different tread.
I would start by lowering the boost, a way to control it over time. Radials don't like to get hit with full power out off the hit. Power management is key to getting a radial to work.
Secondly, what is the rear gear, and first gear ratio of the trans?
My setup was very similar to yours not long ago.
Are you running a stock rear end? Stock springs? Stock torque arm?
I'd move the LCA to the middle hole and see what happens, then be prepared to bring the torque arm down on the cross member.
Raising the nose of the torque arm and having the LCA in the lowest hole is going to hit the tire the hardest, so you need to back it off somewhere.
First pass tires at 20 psi. Transbrake 3500 rpm launch. It spun and fished tailef then it hooked good. 1.927 60 ft
Second pass tires at 18. Foot brake 1500 rpm 2 step. 50 shot hitting at 3000. Spun alot before it softly hooked.
