hook help
Next time you race can you have someone stand right beside your car and video your launch from the side? That way we can see what the rear tire and suspension are doing.
Sounds like you have stock rearend, stock LCA with adjustable brackets, stock TA with adjustable crossmember, stock rear springs with CE 3-way adjustable shocks and stock front suspension. Is that right?
Then one adjustment at a time for a couple of passes starting with 15 - 18 psi in the radials and a good 5 second burnout. Then adjust your LCA up one, then your TA. It will take some work and time.
That will help you make the most of what you have but you're going to need to stiffen up the suspension to hook off the trans brake on full power. Your stock springs and suspension can't take the shock. You're going to keep unloading the tires. Coilovers, LCA, TA, PHB, etc. Then kiss your 10 bolt good bye.
The car has too much anti squat and is hitting the tires too hard.
18-20 psi is a good window.
Make sure the shocks are set on 50/50.
Is the front swaybar removed?
