Drag Racing Tech
Cloyes LS 3-keyway timing set
Old Jul 4, 2017 | 02:41 PM
WV Z06's Avatar
Default Cloyes LS 3-keyway timing set
I have a Cloyes race timing set for my LS3 race engine that has the 3 keyway crank gear and non adjustable cam gear. How many degrees will the advance keyway advance the cam timing? This is the part #9-3672TX3Z. I have seen it listed as 8 degrees adjustment ( I'm assuming 4 advance, 4 retard) and I've seen 4 degrees advance but I wasn't sure if it meant 4 degrees crank and 2 cam or if it is actually 4 degrees on the cam. Any info appreciated. Thanks
