Drag Racing Tech
Run consistency with turbo
Old Jul 11, 2017 | 09:37 AM
stcloudguy's Avatar
Default Run consistency with turbo
My son and I bracket race a 3rd Gen Camaro that's been back halved. Running a 408 forged short block with stock 317 heads, LS6 intake, and a 76MM Precision turbo at 13 pounds of boost. This past weekend we made 4 passes between 9.209 - 9.232. Wondering what other turbo guys experiences are. To some of the locals with a standard NA carburetor motor, that's a huge range.
Old Jul 12, 2017 | 06:39 PM
Taxman20's Avatar
Yea, I was a bracket racer too in Top Dragster, now I drive a no prep turbo S10. Its definitely not as consistent. The spool psi at launch will vary a bit, its near impossible to be within .5 to 1 psi from launch to launch and thats a hp difference. But your times are pretty good really. I dont know anyone that runs then with a dial in car.
Just run no prep / grudge events and have fun.
Old Jul 17, 2017 | 01:58 PM
T6Rocket's Avatar
A 2 step will set the RPM (and boost) the same every run.
Al
Old Aug 11, 2017 | 11:08 AM
tittan1500's Avatar
yup the 2 step and bump box makes them consistent
Old Oct 2, 2017 | 11:18 PM
Rick01SS's Avatar
A bump box isn't going to give you consistent staging, hence your rt is gonna be all over the place. I'm looking to go procharged for bracket.
Old Oct 3, 2017 | 09:28 AM
Taxman20's Avatar
True, a bump box doesnt make it perfect but it helps. The issue is your boost level at launch. I normally leave at about 13.5 psi. On a test the other night I let it spool an extra couple of seconds and left at 20 psi. 60ft went from 1.35 to 1.16. So it makes a big difference. Thats the hard part to control, the boost levels.
