Drag Racing Tech
Lower control arm angle
Old Jul 27, 2017 | 09:25 AM
jlrz28's Avatar
10 Second Fun Car
Default Lower control arm angle
Replaced my poly ones with rod ends and noticed the angles are the same as before but the angles are different on each side. I've got 4 degrees on passenger and 6 on driver side. I have adjustments on the rear end to move them but it's been fine hooking up. Car is stock height not lowered.
Old Jul 27, 2017 | 10:39 AM
MidwestChassis's Avatar
LS1Tech Premium Sponsor
Control arm angle is relative to ride height. Does the car have coil-overs or stock springs and also does it have an anti roll bar on it?
Old Jul 27, 2017 | 10:42 AM
jlrz28's Avatar
10 Second Fun Car
Stock springs, qa1 sa and a Spohn anti-roll drag bar.
Old Jul 27, 2017 | 10:58 AM
If the car is working I would not worry about it.
Old Jul 28, 2017 | 01:23 PM
93camaro_zzz's Avatar
It sounds like the car is leaning or something. I mean, think about it, if the rear end is square (including the LCA mounts), and the body is square, then the car is leaning to one side.
Old Jul 28, 2017 | 04:32 PM
jlrz28's Avatar
10 Second Fun Car
The car is ~20lbs heavier on the passenger rear, compared to the driver side. Then I am sure with me in it it moves the other way.
Old Jul 28, 2017 | 07:59 PM
BOLO's Avatar
You probably need to adjust your anti roll bar. Also make sure that the rear end is truly centered---adjust the pan hard bar if needed. GL
