Nitto Drag Radial Not Hooking
The answer to running radials with a manual is proper use of a clutch buffer. No need to use bias slicks to get consistency. Some are able to buffer the clutch using their foot, but it takes a lot of practice. Here's a list of alternatives to using your foot-
http://magnusmotorsports.com/product...ontrol-device/
http://tiltonracing.com/wp-content/u...trol-Valve.pdf
http://www.clutchmasters.com/content/FCV2000diagram.pdf
http://ClutchTamer.com
You will get the most benefit from using a clutch buffer to match the hit of the clutch to the engine's power. Using it to chase track conditions is setting yourself up for frustration.
Here's the difference-
...When matching the clutch to the engine, the tires stay dead hooked and the clutch slips to control bog. The buffer is used to force the clutch to slip longer than it wants to by temporarily withholding some clamp pressure. It's basically a timed event that doesn't vary much with conditions. Since this scenario keeps the tires dead hooked, it's radial friendly.
...When matching the clutch to the conditions, the buffer is used to adjust the hit of the clutch with the goal of hitting the tires hard enough to make them spin just the right amount to control bog. Basically trying to walk the fine line between too much spin or not enough. Missing it either way can have a huge effect on power production.
Guess which method places less stress on transmissions and axles.
Grant
Grant
If you plan wot shifts with a radial, Softloc or any centrifugal assist clutch isn't the answer.
Grant
Race your car!
Grant ever actually build a fast car?
Ever have, or work on a fast stick shift car, something with a Liberty or the like?
Before you go shooting your mouth off about gimmick junk designed to make 1/2 *** setup's work, or are nothing more than a driver bandaid, or an attempt to make something work like a real race part at 100 pct the cost of said parts longevity... think a little. Not everyone in here is a clueless asshat about this kind of stuff.
