MWC 8 point roll bar install questions
You want to try and keep the angle of the shoulder straps at 10 degrees or less if possible. Too much angle can pull down on your body if you were in an accident, and compress the spine. Shoulder straps are primarily just to keep you from moving forward, while the lap belts keep you seated, and submarines keep you from sliding out. It may just be the angle of the picture, if so disregard!
It is a significant pain in the *** lol. I wrapped mine in plastic and it was really tight. Parts of it ended up getting smashed in pretty good, but it still looks better than no headliner.
The easiest way to do a rollcage and keep the headliner is to remove the front window pull it out from that opening and reinstall it back through that opening. It does still take some finagling but makes it easier if you want to keep the headliner and not worry about burning the headliner or getting paint on it.
Not sure where pre-bent cages sit on the floor. My car I did the old way. Bent the main hoop, halo and front bars all set up on loose floor plates. Marked where I needed to drill holes to drop those 4 legs through so I could weld all the tops then picked it back up and put the plates under. Also painted the top half before picking it up. Never even took the headliner out.
Thats a good way and was suggested to me. I did the 75% weld rule and added gussets at every intersection of pipe. Seemed like a quicker easier option for a first time cage install.
the easiest way to do a rollcage and keep the headliner is to remove the front window pull it out from that opening and reinstall it back through that opening. It does still take some finagling but makes it easier if you want to keep the headliner and not worry about burning the headliner or getting paint on it.
