Drag Racing Tech
HARDCORE Drag Racers within!!!!
Old Jul 1, 2004 | 12:41 PM
JS's Avatar
JS
Default HARDCORE Drag Racers within!!!!
I need some help......
Here's my data and I want recommendations....
H/C car A4/4.10's 26in slicks (Peak HP 6150 carries to 6400/Peak TQ 4700)
Launch Car 2500
Flash vert 4300
1/2 shift 6100---->Verter dropped back to 5300 (800rpm)
2/3 shift 6400---->Verter dropped back to 5400 (1000rpm)
Cross traps at 6200
Run 2
Launch 2900
Flash vert 4400
1/2 shift 6200/5500---->(800rpm)
2/3 shift 6400/5400---->(1000rpm)
Cross traps at 6300
My question is ,What should I be shifting this car at guys
It peaks at 6100 but carries it to 6400.
2nd
My peak tq is 4700,I believe this verter is right on the money for flash(4300/4400)and dropping in between shift (800 to 1000)?Am I correct in my thinking?
3rd
Where should I shoot for going threw the traps for max et according to my peak power?
4th
Is a 26in slick gonna be enough,or should I run a 27in?
Need info........
Old Jul 1, 2004 | 01:35 PM
gator's 99TA's Avatar
IMHO, 6500 rpms minimum for peak performance. peak tq really isnt an issue to big stall convertors i feel. even at your raceweight, i think a 26" tire is gonna be fine. just fine tune it and 1.49 should be on your doorsteeps. i would shoot also for 6400-6500 through the traps. probably still nice and safe at that rpm. also try to stall that convertor as close to 3K rpms as possible. it is a 4200 stall right?
Old Jul 1, 2004 | 02:05 PM
JS's Avatar
JS
Yes the verter is a 4200,Seems to flash right at 4200 /4400.Drops back no more than 1000 which IMO is perfect.I was thinking 122 mph should be right around 6500 which again would be perfect for my 26in slick.
6500 it is then for the shift points.
Thanx....
Steven,Coach,Raugh,Bob anyone else have an opinion?
Old Jul 1, 2004 | 02:23 PM
93LS1RX7's Avatar
I would say shift 6500-6600 for your best bet. You are falling to far down away from the power when you are dropping to 5400rpm. To see for sure you would want a dyno to see if the later shift is less of a drop off than the low rpm I would guess it is.
Old Jul 1, 2004 | 02:30 PM
Silvr98z28's Avatar
I have a very similar combo. Also on 26" slicks. I shift at 6800 and cross at 6800 - 6900.
Old Jul 1, 2004 | 02:41 PM
CHRISPY's Avatar
I agree with this as well. Try to cross the traps at about 300-400rpm past your power peak. No need to spin it to the moon if you want the motor to live a long time.
I think you just need to fine tune the suspension/tire pressure and you'll hit low 11's.
Old Jul 1, 2004 | 03:31 PM
JS's Avatar
JS
I would think if I bump BOTH shifts up to 6500 it wont drop lower than 5600rpm which should be fine for my combo.I need to get my shift points bumped up,and try and go over the traps at 6700.I'm staying w/26in boots,they should be perfect for my combo.
Time to take some more weight out of the car
I love this setup..
6500 MAX shifts and no worries about revving it to the moon.
Pipster I love the new name...
Your funny bro...
Old Jul 1, 2004 | 09:51 PM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
JS,
Stall that sucker up as high as it will go without pushing through the brakes. When I stage the car. I get on the convertor until I feel the *** end comes up. I hold until I see the 3rd yellow come on then I nail it.
You need to make both your shifts at 6,500 to 6,700 rpms. Set your shift light at 6,400 rpms and go for it Brother.
Try my advise, I think you will dig what happens.
Good luck.
Coach
Old Jul 1, 2004 | 10:40 PM
Colonel's Avatar
What Coach said.
Old Jul 1, 2004 | 10:41 PM
Navy David SS's Avatar
Coach
I thought you had a trans-brake?
How about this: set your 2-step at 3500, hold the trans-brake, release - wouldn't this actually flash your converter (if it was say a 4000 stall) to 4300?
David
Old Jul 2, 2004 | 08:50 AM
JS's Avatar
JS
Thanks guys,I'll get those shifts set at 6500 and stand on her up to 3000...
11.40's in soup DA's here I come
JS
Old Jul 2, 2004 | 11:01 AM
CamaroCain's Avatar
whats your race weight?
Old Jul 2, 2004 | 12:16 PM
JS's Avatar
JS
Well if I had to guess I'd say the car is 3550lbs but I'l get u an exact weight this week.
I figure 340 (ME) and 3200 for the car but lately I've been thinking the cars heavier than that with me out of it.
I want 11.40's out of it in high Da's...With my mild setup (Cartek LS6 S2/224-580) that would make me happy,I'd run low 11's in good air and just be a cam change from the 10's..
Old Jul 2, 2004 | 03:27 PM
The Juggernaut's Avatar
With a transbrake,hold the button and put the gas to the floor.(This will show you true stall.) let go of the button on the third yellow.
I shift 6900-7000ish.
Everyone says " your engine will not live long shifting that high".
I have over 225 passes shifting that high.Probably 100 LAUNCHING that high when
I had the M6.
So don't listen to me, I don't know what I am doing.
Old Jul 2, 2004 | 06:09 PM
why is everyone talking about a transbrake? JS has a transbrake?
Old Jul 2, 2004 | 11:59 PM
JS's Avatar
JS
Nope....
Old Jul 3, 2004 | 09:55 PM
StreetStalkerZ's Avatar
Hmmmm 3000rpm drop huh? I'll try that friday night with mine and see if i can do any better.
JS,me and you would be a good run I'm running 11.50s in 2800-3000 DA right now.
Old Jul 3, 2004 | 11:38 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Yah stall up the Yank as high as you can and shift as high as necessary, I'd adjust shift points until the car stops gaining. I'm sure 11.4@118mph will happen next time.
Old Jul 4, 2004 | 01:26 AM
JS's Avatar
JS
I;d really be happy with that John,especailly in +2000ft of air.
The car is over 3550,I'm gonna weight it this week....
