Recommendations for Build *specs inside*
413 cid LS2 from Scoggin Dickey (EL TORO GRANDE)
• Cylinder Block: LS2 Aluminum, 6 Bolt main, 4.005” Bore
• Crankshaft: Eagle 4340 Forged Steel, 4.100” Stroke
• Connecting Rods: Scat 6.125”, 4340 Forged, H-Beam
• Pistons: Manley Dished Pistons, 8cc
• Piston Rings: Akerly & Childs Ductile Moly
• Camshaft: MTI “S1” custom cam for 400 cubic inch and up motors ( unknown specs)
• Timing set: HD Single Row
• Reluctor Wheel: 25x
• Fast 92 Intake Manifold
• Nick Williams 92 Throttle body
• Patriot Performance Heads
64cc stage 2 heads
650” Lift springs
Titanium Retainers
Super 7 Locks
21-4N Stainless steel High-Flo valves
2.02” Intake Valves
1.57” Exhaust Valves
5 Axis CNC Ported-Polished Heads
Harland Sharp Rocker Arms
NGK TR6 .35 Gap
AC Delco O2 sensors
• SLP Air lid and K&N air filter
• 180 Degree Thermostat
• Walbro 255L inline fuel pump
Exhaust:
• Corsa cat back exhaust
• QTP Electric cutout
• SLP equal length long tube headers
• Random Technology high flow catalytic converters
• SLP smooth high flow bellows
What I am looking for is 520-540whp NA and add a 200 shot. Currently make 502/486. I need suggestions like a better intake, bigger primaries on exhaust etc etc. I would like to keep what I have as far as heads and block and just rebuild/refresh but if you think my components are better on a different head I could be game for that. Just if you have some time please holler, thanks.
I think you can keep your heads, cam, etc. and change those things and get the power level you want. It's definitely possible.
I figured that but was not sure, would all those components move over to AFR or TF bare heads (springs, guides valves etc)
Another quick question, will my assembled head accessories move to the TF heads?
TF 245 or equivelant
2 inch primaries
102 intake MSD or Fast
Cam around or close
247/255 cam, 111 lsa, .632 on both the intake and the exhaust
I should mention Ill be going E85 because im hoping to be 12.5 comp for nitrous.
2 inch primaries
Cam around or close
I'm not yet educated on E85 so I can' help you with that part but it sure does sound good!!
I would go Tfs heads myself due to the valve angle and more track proven results...
