break in the 10's theory build
Having converter re stalled to a 4400 for just a bit more shift extension. Spinning to 7000 rpm's looking for extensions around 6300.
Hopefully 10.8 in the spring
Here is a copy and paste from aopa
What Is Density Altitude?
Density altitude is pressure altitude corrected for nonstandard temperature. As temperature and altitude increase, air density decreases. In a sense, it's the altitude at which the airplane "feels" its flying.
Hopefully that helps, the higher the elevation the less oxygen and pressure there will be. In n/a cars, for every 1,000 ft. it tends to be about 1/10 second. So say with a da of 0 ft. you run 13 flat..... with a da around 3000 ft you would run roughly 13.3 - 13.4 and lose about 3 mph on your trap speed. Now say your da is negative like -1000 ft and you previously ran 13 flat at 0 ft you could see times around 12.8 and gain a couple mph.
That's why you see guys in like Denver running mid 14's or worse with stock Ls1's because there starting track elevations are 5,000 ft + above sea level and sometimes see da's close to 7000 ft.
Hopefully I worded all that so it kinda makes sense.
Here is a da calculator you can mess around with and also correct your times to give ya a idea of what you would run at sea level if you have very poor day's.
http://www.dragtimes.com/da-density-...calculator.php
https://wahiduddin.net/calc/calc_da.htm
Early spring or late fall 40-45 degrees, high barometer, my car will run 10.0x at 133-134.
Lots of trial and error.I would tune to no end, changed gears, different stalls, rebuilt trans, always something.....and then it happened.
Keep the faith.
3420# with me in it
