GTO inconsistencies
Any advice, she said it shifts fine just feels really slow.
She deep stages and the 60ft times go from 1.98's to 2.10's but it isn't spinning.
Thanks,
Jeff
It's difficult to say exactly what it is without a way to log the car, but I'd check with the tuner.
I've raced with you guys before; my name is Chris, I have a Pewter Z28 with black wheels. I talked with you and Rob at OSW a few weekends ago.
I have HP Tuners and have tuned my own car. I'd be interested in what the Intake Air Temperatures (IAT) were on all of those passes; there are spark modifiers for IAT and Engine Coolant Temperature and those can move the timing up and down. If the timing was advanced any above stock in the new tune and the car experiences any knock, the PCM can pull timing out and slow the car down as well.
Is it a 5.7, or a 6.0? If it's a 6.0 it might be worth looking into relocating the IAT sensor away from the MAF housing.
Let me know if I can help out.
Thanks,
Jeff
As for suspension- if it still varying like that you have issues or not enough traction. Put a slick on it ditch the radial if you’re on a radial- slick will be more consistent on an inconsistent starting line.
