Drag Racing Tech
Front tire pressure?
Old May 29, 2018 | 12:23 PM
fsvaasam's Avatar
Default Front tire pressure?
New to drag racing with my 3gen nova A4 LS1. Stock bottom, ported 853 1 7/8 and TSP228 Yank 3600ss 3,42 rear. Only getting 109mph 12.56 / 1,98 on unprepped old airfield. Should i have more speed? Im using M/T 255 streetradials and BFG 215/70/15 in front.
Stock steering and like novas do, alot toe-in when acceleration. I went with 32psi in front and im planing to go 44psi next time. Have you any experience how front pressure behaves with top speed or am i chasing wrong here? What you think speed should be? Sea level altitude.
Old May 29, 2018 | 01:01 PM
01ssreda4's Avatar
Ive tried from 25-45 with no change in et. Anything over 25 is stable at high speeds from my experience.
Old May 29, 2018 | 02:33 PM
nj02z's Avatar
I use tire pressure to control reaction time,usually between 34/40.I do not see much variation in et/speed.
Old May 29, 2018 | 04:06 PM
Doug G's Avatar
I run up to 5psi over max stated on sidewall.
Old May 29, 2018 | 05:02 PM
ragtopz28's Avatar
Similar here...I run 42 in a M&H radial that calls for 40. It's all about rolling resistance regardless how minuscule.
That 17" radial is awesome at speed.
Old May 30, 2018 | 09:23 AM
fsvaasam's Avatar
Okay, thanks for info. Talking about rolling resistance, i found one picture from event and front tyre looks very stupid position to me. Thats why i thougt im missing top speed cause of this.
https://photos.google.com/share/AF1Q...hLVER2NHJyM3dR
Old May 30, 2018 | 07:44 PM
ragtopz28's Avatar
That does look jacked...get a "drag" alignment!
Old May 31, 2018 | 08:25 AM
fsvaasam's Avatar
Alignment can be one solution this point, but not worth the hustle. I drive so much on street also. There is available rack&pinion kits for nova which eliminates bumpsteer and im buying one soon. Try to raise pressure to next event and see what happends.
Old May 31, 2018 | 05:22 PM
Doug G's Avatar
You have trick springs ? or drag shocks ? or both ?
have them jack up the front about 1" and then do a "factory" alignment.
Old Jun 1, 2018 | 05:45 AM
fsvaasam's Avatar
Its my first time on track for me and car with streetradials. I have fairly stock suspension. 2" lowering springs with regular shocks and 5 leaf stock springs with 1" lowering blocks.
Old Jun 1, 2018 | 06:02 AM
8.Lug's Avatar
Whatever the max pressure says on the tire.
