How much does 60' affect MPH??
Im dealing with the same thing with my cobra, My car will make good dyno pulls, but when I throw the sticky's on it best I can get in low 1.7's and the clutch will slip more and more on each shift, everyday driving it is fine on street tires. I know im not a ls1 by anymeans, just thought I would share. I think I am giving up close to 2-3mph on the big end and at least 2 tenths.
My buddy was also at the track this weekend with his H/C 100 shot 02 Vert SS and his spec3 took a dump and got soft, he went from 60ft mid 1.5's to 1.7's in a hurry and the car was hurt everywhere else as well, I will get some specifics from him but it was not pretty.
Good Luck.
its really more HOW you get that sixty foot..i.e- is the car spinning really bad, bogging real bad, or dead hooking nicely.
myself and most others that race alot here will tell you a nice dead hook will result in the best mph. the theory that a bunch of spin will create more MPH is pretty bunk. if you think about it if you are spinning you are just not gaining ground and wasting rpm band, the car will mph less.
to be fair. a mild spin will create more mph than a real bad bog, its always better to keep the car up in the rpm band rather than let if fall and make the car have to fight its way back into the power band.
broke7's comments can apply to my last comments about spin vs bog. a badly slipping clutch will have some similar effects on the car through the sixty foot and the power band as well.
Why? 60' at the end of the pass doesn't allow you much acceleration, hence if you shortened the dragstrip by 60' your MPH wouldn't change much.
I can smoke the tires for 60', shift early and still end up within 1 mph of a good hook, nice shift run.
Differnce is quickness(e.t), not top speed.
Once I saw what my consistent mph was I tried to get my e.t. to match up.
112 mph over and over at 12.6-13.1 until I got a few 12.3x runs and figured that was about it!
My e.t. improvements all showed in the 60' on my timeslips.
later
tim
