Drag Racing Tech
Anyone take the TCS off?
Old Jul 3, 2004 | 10:34 AM
The Juggernaut's Avatar
Default Anyone take the TCS off?
Is there a cable that just goes from the pedal to the TB?
That whole system looks like it has to weight 15-20#.
If anyone has a part number for a new cable, or any tips, please let me
know.
Thanks, Sean
Old Jul 3, 2004 | 01:49 PM
SilverGhost's Avatar
Motorboater
what, mister king of lightweight hasn't done this one yet
all you need is to call up a dealer and say you want the throttle cable for a non traction control car for your year, or any year really. takes 2 minutes to swap out, the new cable just goes right from the peddle to the TB.
i did this a year ago, much better not having that crap there visually, but yeah it weights a few lbs ,too.
Old Jul 3, 2004 | 03:12 PM
Does the throttle cable bracket have to be changed?
I always thought about taking it off,then today a was underneath the car
and saw ANOTHER big metal box attached to the frame by the front wheel.
I've had the car apart 100 times and never noticed it,traced the cable to
the TCS.I don't know if it's the cruise control or what...but it is soon to be
garbage.
Old Jul 3, 2004 | 03:27 PM
Motorboater
nope, bracket on the intake for the cable stays the same, just swap the cables, plug n play baby
Old Jul 3, 2004 | 07:31 PM
Nice.
I like being lighter.
Old Jul 3, 2004 | 11:53 PM
Jason99T/A's Avatar
I can shift faster than you.
I did this awhile back. It does clean up the engine bay quite a bit, plus the weight savings is always nice. You will loose your cruise control when doing this. As Sean said, order a throttle cable from a non-TCS car. This will connect your pedal to the TB directly.
Old Jul 4, 2004 | 01:16 PM
Well right after I posted yesterday, I went to the chevy dealer....parts were closed.
So I came home and you guys posted and confirmed what I already thought.
So being the patient man that I am, I decided to rip it all off today.
Pulled it all off and decided since I need to buy a new cable anyway,why not
just modify the existing one?
I measure, cut the housing(removed it) and it works perfect!
Total cost $0.00
Total weight savings about 8 pounds.
Less weight than I thought by looking at it, but oh well, 8# is alot to me.
Old Jul 4, 2004 | 01:31 PM
Motorboater
cable was only 13 bucks on big discount over at jennings
Old Jul 4, 2004 | 01:35 PM
13.00?...must be nice to be rich.
Old Jul 5, 2004 | 09:14 PM
Damage Inc.'s Avatar
Sweet Cheeks
Is there more than the cables and the little cylinder by the battery? What else comes out with the TCS? Where is it located?
Old Jul 5, 2004 | 09:18 PM
the third cable runs to a box in front of the drivers front tire.
I had 3 cables total.
pedal to the "little cylinder"
"Little cylinder" to the TB
"little cylinder" to the box( I think it is the cruise control)
Old Jul 5, 2004 | 09:20 PM
Jason99T/A's Avatar
It is cruise control.
Old Jul 6, 2004 | 10:33 AM
Sweet Cheeks
So the little box can come out too?
Old Jul 6, 2004 | 02:35 PM
yep, 2 bolts.
Leave the cable in it.
Disconnect from the "little cylinder" and feed it down.
Old Jul 6, 2004 | 02:54 PM
Sweet Cheeks
Awesome, thanks.
Old Jul 6, 2004 | 10:30 PM
theblur98ss's Avatar
I'm curious how you modded the original cable to work. Does it have the little piece on the end that goes into the throttle body? I went to my local gm dealer but they have a new parts guy that is a total rimjob and I refuse to buy off them.
Old Jul 7, 2004 | 01:37 PM
I just cut the housing back to shorten the housing(still using the original end)
It doesn't fit as well in the TB bracket, so I just used some electrical tape across the top of the bracket to make sure it doesn't slide off.
Old Jul 7, 2004 | 03:07 PM
xaon's Avatar
does this throw any codes? Permanent TCS Off light on the dash?
Old Jul 9, 2004 | 03:04 AM
Jeffs99SS's Avatar
I was wondering about any codes, as well.
Also, is there any way to remove the TCS while keeping cruise control, or is that a major PITA? I would really like to clean that mess out of the engine bay.
Jeff
Old Jul 9, 2004 | 12:04 PM
Jason99T/A's Avatar
No codes, just a permanent TCS/ASR off light.
