What tire will hook better? Width vs Height?
Stiff wall tires are usually meant for stick stift cars. Something to think about.
You never said what you are doing with these tires, but since it's in the drag racing section, I would go to a 15" tire if possible. Or a 275/50-17 if you're stuck with 17's. That is basically a 28x10 tire.
Al
Al
One of the issues with height is gearing which is one of the reasons i said width so gearing didn't have to be changed.
For example I could "peddle" my cam only ls1 4th gen with 4k stall converter, to low 12's on my g-tech with 295/50/15 cheap Nankang street tires. With anything smaller it couldn't do that.
Another ls1 daily driver I have, I went 2 sizes up in rear tires recently and they are cheap chinese tires and they're wider than they are taller and I was surprised it hooks much better.
If Nankang or someone else made a cheap 325/50/15 true street tire i'd run them now and then on my Camaro instead of needing drive around on expensive hoosiers/m/t's all the time.
This was about 4-5psi in first gear.
