Drag Racing Tech
How To: BURNOUT REV LIMITER?
Old Sep 17, 2020 | 06:25 AM
rel3rd's Avatar
Question How To: BURNOUT REV LIMITER?
HPTUNERS tuned
Turbo LQ4 with 4L80E Jake's D-1 transmission
MSD 2 step works with, and wired in conjunction with, Transbrake, which is normally set at anywhere from 3000-4000 depending on boost level choice for that day
Is there a way to have a 2nd LOWER rev limiter, used for my burnout only? Similar to an MSD THREE step?
Since the turbo swap, when doing a burnout, it takes a bit more throttle to get the tires spinning, then it almost free revs, and does so a little higher than I'd prefer. I balance it's RPM the best I can, but would like a different solution, if there is one.
Old Sep 17, 2020 | 10:33 AM
MaroonMonsterLS1's Avatar
https://ls1tech.com/forums/generatio...733-units.html
Old Sep 17, 2020 | 01:18 PM
rel3rd's Avatar
Originally Posted by MaroonMonsterLS1
Thanks for that link.
I wish the guy had reported back, or elaborated a little about how he did it. I'd be scared of flyback current/feedback, using 2 MSD units in sync.
My other option, which is much cheaper...is to simply put the transbrake wire on a toggle switch, but then I think that would hamper the burnout, limiting it to 3000-4000 rpm.
Old Sep 17, 2020 | 10:47 PM
jayyyw's Avatar
The Lingenfelter 003 has a 2 step and 3 step function.
Old Sep 18, 2020 | 05:31 AM
rel3rd's Avatar
Thumbs up
Perfect! Thank you!
I used an LNC-2000 when the car had nitrous and it worked great. I'm sure this one will work great as well.
Old Sep 18, 2020 | 06:38 AM
jayyyw's Avatar
I used it for a little while. It worked perfect.
Old Sep 23, 2020 | 12:29 PM
Lbzdmax07's Avatar
How are you doing your burnouts? I have a similar setup but not much seat time
Old Sep 23, 2020 | 01:43 PM
rel3rd's Avatar
1st into 2nd, hold for a few seconds and let off the brakes and gas letting it bite in...
With the turbo, it usually acts like it doesn't want to get spinning, then cracks open to redline, damn near, lol
Here's one from a few months ago, only the 2nd pass on the turbo combo, but you can hear/see burnout pretty good.
Here's from this past weekend, with some street tuning, and more seat time...(the rumpity rump cam, loud car is the all-out drag car I raced, but you get the point, I guess, lol)
Old Sep 24, 2020 | 07:06 AM
You're asking for a sprag failure with your burnout method
If you keep letting the tires "bite" in 2nd it is very hard on the sprag
If you don't have the power to start your burnout in 2nd (recommended) then you don't have much option to start in first,
But when you do get the burnout going, shift 1-2 then make sure to click it into 3rd gear before you roll out and let the tire bite
Old Sep 24, 2020 | 08:00 AM
rel3rd's Avatar
Question
I been lucky then, I guess. Couple hundred burnouts this way. Never heard about not letting it bite in, in 2nd gear. This is a 4L80e, if that makes any difference?
Only 1 time did I "accidentally" shift into 3rd, and it immediately dogged the engine down.
Are you saying start off in 2nd, and leave it in 2nd still? or am I misunderstanding?
Thanks.
Old Sep 24, 2020 | 11:10 AM
4l80e and th400 share the same int. sprag and dynamic
There are lots of guys that do it your way...but it is still not the recommended method.
Start in 2nd, shift to 3rd, then rollout and end the burnout. That is the preferred method.
After being in 100+ 80e/400's I can tell you that those guys that end their burnout in 2nd...we can usually tell. The dogs of the sprag usually have noticible wear marks as does the race.
Not saying your burnout procedure is certain death...it's just unnecessary risk and wear
Old Sep 24, 2020 | 11:25 AM
rel3rd's Avatar
I'll try the 2nd into 3rd next time out, and report back. Thanks!
