Drag Racing Tech
How to launch??????
Old Aug 22, 2002 | 10:00 PM
White98Z's Avatar
Default How to launch??????
With my setup how would you launch it what rpm and what ever eles I am Running the 315/35/zr17 nittos in the back what psi should they be at and what could i get to drop the 60s more the best i have got is 2.20
Old Aug 22, 2002 | 10:02 PM
White98Z's Avatar
Default Re: How to launch??????
Sorry forgot the sig
Old Aug 23, 2002 | 01:42 PM
dug's Avatar
dug
Youre gonna have to be rude to the clutch and slip it. I managed a 2.1 short time on a well prepped track with 245 50 16 sumotono tires. I slipped the clutch out at around 3000. The way the track was hooking I think 1.9 would have been possible with practice.
The key is to avoid and jerks or jolts when letting out the clutch. This will break the tires loose and then its all over. Also, you have to be carefull not to slip the clutch too much or else it will get hot and not grab. I got another 2.1 60 ft time this way and the clutch slipped up to 5000 rpms before it grabbed. That was bad for the clutch and didnt give me a better 60ft. If I would have let out the clutch a little more aggressively it wouldnt have slipped so much and probably gotten a better short time.
Also make sure that when launching you are not starting with the clutch pressed to the floor. Let it up a bit until you feel it start to grab and then push it in a little bit. When slipping the clutch it is not necessary to have it floored. More like half throttle and then you ease into it as the weight transfers. Try practicing slipping the clutch at 1000rpms and then 2000s and keep moving up until you get the launch you want. The key is to launch hard and aggressive while still being smooth at the same time. All it takes is practice and sticky track. Remember when practicing on the street concrete hooks better than asphalt. This would be a way to practice in different conditions.
I know my 2.1 short time hardly makes me an expert . It was my one and only time at the track so I think I am heading in the right direction.
Another important thing is to make sure you are heating up your nittos correctly. The word on the street is they like heat and around 20psi.
<small>[ August 23, 2002, 01:45 PM: Message edited by: dug ]</small>
Old Aug 23, 2002 | 01:44 PM
McRat's Avatar
Run the Nitto's at 15 psi. Heat them for 5-15 seconds. Launch from 3500, and go up as is necessary to eliminate bog.
Your Z06 clutch won't take a shitload of 4500 launches before the hyd overheat. Before each pass, pust clutch to the floor 6-10 times slowly to cool the slave cylinder.
IMO...
Old Aug 23, 2002 | 02:08 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Been a long time since my M6 days but I cut some 1.9's on Nittos...
I put them at 22 psi, do a good proper burnout, linelock is very handy...
I hold rpms at 3000-3500 rpms and let out the clutch and don't slip it. Don't hotlap it.
Old Aug 24, 2002 | 12:12 AM
White98Z's Avatar
ttt
Old Aug 24, 2002 | 12:17 AM
AlienDroid's Avatar
Are you still on the stock rear end? If so I'd launch it easy.
Old Aug 24, 2002 | 12:57 AM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
What rpm are you launching at now? Stock rearend?
What rpms are you shifting at?
