Racecar maintenance schedule??
I drive the car very few miles on the street. I run synthetic 10W-30 (Royal Purple now, normally Amsoil) and regular ATF & gear lube. I have Crane dual springs (832's).
Thanks!
Coach
Coach - you run synthetic oil? Looks like I need to step up my oil changes! My oil looks like brand new on the stick and the pressure is exactly where it was when the oil was new! I have about 35 passes on it.
Didn't know you should rotate slicks - what about ET Streets? Same?
Are you bracket racing this weeekend?
Coach
Coach
I have contacted Royal Purple to see what they say, but I think I am gonna go ahead and get it changed out! Better safe than sorry. I also think I'm gonna go back to my normal Amsoil 10W30 when I change it.
offtopic...
I wish I had a "Coach" here to help me! I have dialed my car to within a hundredth every elimination run for the past 5 Saturdays - it is extremely consistent - I just can't get on the tree! I'm all over the place trying to find my sweet spot.
I think it may be my lazy converter tripping me up. It is a soft hit to go easy on parts, but takes too long to react. If I leave on the last yellow, I am .60x's, if I try to anticipate the last yellow, I redlight.
That stuff don't cut it with the big boys in Class II (heavy) - they are tough!
I think if I start trying to stall it up another 500 or more rpm, it will soak up some of the stall time and help my reaction times off of the last yellow. I'll try it next week - sound right?
Thanks again all!
Before Every Race:
Check torque specs on rear suspension parts
Double check all shock settings
Inspect all tires, dimples/wear/pressure
Check lug nuts
Inspect engine bay
Empty the catch can from the vacuum pump
Every Other Race:
Check the lash on my T&D Rockers
Oil Change
-6 Quarts Royal Purple Racing 28
-K&N Oil Filter
End of Season:
New trans gasket
Fresh trans fluid
-Royal Purple ATF
Freshen rear end
-Check Ring/Pinion wear
-New gasket
-Fresh gear oil, Royal Purple MaxGear 75w90
I send my TH400 to JW for "freshening" every 2 seasons. And I will be sending my motor to FMS for "freshening" at +300 passes.
I don't run an air filter, if I did I would check that every other race. As for my slicks, I am replace them right at about 50-60 runs right now, My car likes a fresh set best.
Lee
