Will Drag Radials Help?
Also, does lower air pressure in the rear tires slow the car down as far as trap speeds are concerned? Thanks...
Dan
<strong>You may want to try drag radials just for the insurance of the traction. Plus, they're designed to run with less than normal pressure. You may also want to try normal pressure with your standard radials. That should actually help traction more than lower pressure. It will also help stabilize the ride.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That's just it though. I wasn't having any traction problems at all. I'm wondering if Nittos will reduce my 60'. I think I need more mods to do that since I got so much traction I actually bogged on my first launch. Stability isn't an issue since I launch straight and it stays damn near perfectly straight.
Thanks for the reply. Anyone else?
I would try 32psi to start, if you hook leave it alone. Less pressure will cause more rolling resistance.
EDIT: It sounds like you need a converter <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
<small>[ September 20, 2002, 08:20 PM: Message edited by: XFiveLiter ]</small>
With that trap speed and 60 you should be in the 12.80s or 12.90s.
<small>[ September 20, 2002, 10:41 PM: Message edited by: XFiveLiter ]</small>
with that mph you should really be better than a 13.2 <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
ive seen a bascially stock A4 formula go 109 with exhaust and lid once, but 111?? <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
but those are M6 trap speeds.. if it were a 01-02 i wouldnt rule it out, but for 111 traps i would imagine the tires would be smoking off the line
if you're spinning nittos will help. Also you can try your stock tires and run 44PSI in the front ones to help your weight transfer/top end
<strong>111 IS POSSIBLE I DID 110 WITH NO ENGINE MODS!!! THATS A FACT</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">M6 or A4?
60' none
330' none
1/8 ET 8.645
1/8 MPH 84.28
1000' 11.169
1/4 ET 13.287
1/4 MPH 111.70
Here was my post:
https://ls1tech.com/ubb/cgi-bin/ulti...c;f=5;t=002357
I did feel that was my best run ever though. I do find it hard to believe that I ran 111mph without headers & a 'verter. I'm sure the 13.2 was right. I've run that about 10 times.
<small>[ September 21, 2002, 12:11 PM: Message edited by: camaro_ls1 ]</small>
hooker cat back
timing tricker
TB bump stop mod
!FRA
MTI LID
K&N filter
!MAF Screen
!spare/jack
HPP3
Fernco hose
No power adder, no heads/cam, no converter. Pretty much stock I guess.
