Paging RUQWIKR(shift point Q).....
Chris
<strong>He probably went negative because of Torque Management. I had mine set at -5 and it helped. But thanks to Ed Wright its gone now.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">All I did as a bolt-on car was to push rev limiter to 6600 to keep from banging off it on the 1-2 and 2-3 along with 0, 1, or +2 on the 1-2 and no change on the 2-3. In fact, I could not statistically tell a difference with either of the 3 settings with 1-2 on ET or mph.
As far as torque management, it and the REST of the cal was stock. I had PCM with the torque management out but did not show any repeatable gains. I don't want to start the old argument of pro/con to TM. I prefer to leave it in for durability concerns.
Now that I am H/C, I have only had about 10 runs with it like that and have been playing with shift points and limiter settings. No run has been clean on both shifts as far as hitting the limiter (6600-7000).
BTW, you can tell Bob2of3 to get ahold of me once in a while as he has fallen off the face of the earth.
I was just confused cause you had written you went +2 on the 1-2 and then -2 on the 2-3 w/ a 6400 limiter <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> i'm hoping to play with the car in the next coming week. thanks again.
Chris
<strong>Thanks for the info!!
Chris</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The 6400 limiter was with the 3.23's last fall. This spring, when I changed to 4.11's in a 12-bolt, I pushed it to 6600. Now, with h/c, the limiter is 7000.
