Drag Racing Tech
1/4 mile question
Old Oct 14, 2002 | 03:33 AM
NXtremeLS1's Avatar
Default 1/4 mile question
OK guys and girls I know you all have heard this guestion before, but what should I expect to run at the track? I will be running the 1/4 mile, located in northern Virginia so elevation is not a issue nor is the temp. (around 50 deg.) The only reason I am asking is because I am suppose to set up a grudge match with a friend running consistent 12.10's on street tires and I don't want to lose. Here are my mods. I have a 2000 Camaro SS with every possible bolt on, FLP's, 3" x-pipe with bullets, SY 4000, shift kit, 3:42 gears. I will be on welds and 275 BFG DR's. I also have some minor weight reduction. Sorry the post is so long. Thanks Jimmy
Old Oct 14, 2002 | 07:09 AM
boomcase's Avatar
Default Re: 1/4 mile question
Id say if you get out the hole it will be a close race meaning the best driver will win that day.Good luck,
