Question about track prep
talk to other people at the track see how they are hooking compared to normal.
walk out on the starting line if you can and see how hard your shoes stick.
Other's who race frequently will definately tell you if the track is good. I go by the way my car launches and feels when it hooks good.
It also has to do with the type of concrete the track has, as well as how much rubber has been laid down over time, whether there is moisture under the rubber and how warm it is. Then you factor VHT into the equation.
Now track prep is only 1/2 the battle for launching a good 60'. You also have suspension parts/configuration, tire pressure, and launching rpm/technique. You can use these to your advantage if your not hooking because of the "track prep". Stiffen your shock, lower your tire pressure etc will help make up for poor track surface.
Lee
The twist test is planting the ball of your foot on the starting line, then try to twist your foot. You can have a sticky track but when you twist your foot you will feel the amount of adhesion the track has.
