Drag Racing Tech
Bogarts and silck sizing help.
Old Aug 4, 2004 | 12:44 PM
Damage Inc.'s Avatar
Sweet Cheeks
Default Bogarts and silck sizing help.
I have 15x9.75" rear D10s with a 26/11.5 slick on them. My question is, are there gains to be seen by going to a 10 or 10.5 slick? Can I fit them on my wheels now or will I need to buy 8" wheels? Thanks.
Old Aug 4, 2004 | 12:49 PM
SilverGhost's Avatar
Motorboater
the logic you're using is backwards.
you want as wide of a contact patch as possible.
stick with the wider tire.
Old Aug 4, 2004 | 01:35 PM
JeffT's Avatar
do you have a 26x11.5 et street? Or some other type of slick? I would think that the 26x10 et drag would hook better than an et street due to the different compound.
I run the 28x10.5x15 ET drag on my Bogart SS's (15x9.75") and they fit fine.
Old Aug 5, 2004 | 10:43 AM
Sweet Cheeks
So you can run a 10.5" tire on a 9.75 rim with no problem. Okay. Silverghost, I was told that a narrower tire gives you less rolling resistance and can be a way to increase MPH. Just trying to squeeze every ounce out of it.
JeffT: Are you A4 or M6? What size gear are you running with that 28" tire? Power adder? Thanks.
Old Aug 5, 2004 | 10:50 AM
JeffT's Avatar
M6 on the hose. Was on a 4.10 but it felt soft (1.54 60's) coming out of the hole so I've put some 4.56's in to see what happens. Probably too much gear for 1/4 mile track but all we have in AR is 1/8 and 1000'.
Old Aug 5, 2004 | 11:43 AM
Sweet Cheeks
Okay, well thanks for your help.
Old Aug 5, 2004 | 03:56 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Wider is the way I would go. You can run the wide 26" ET Drag on your D10's. Rich aka Silvr98z (sp) is the king of 60's on those tires.
Old Aug 5, 2004 | 04:04 PM
Sweet Cheeks
Thanks. I saw that he's running the MT DRs on those Bogarts now.
