Drag Racing Tech
just lost 52lbs
Old Aug 20, 2004 | 01:56 PM
mike c.'s Avatar
Default just lost 52lbs
i just finished removing my front sway bar and the entire air condition system. when all was put on a scale i lost 52lbs off the nose of my 01 ws6. i hope all this helps at the track tomorrow.
Old Aug 20, 2004 | 02:13 PM
cyphur's Avatar
lol f#ck all that. a/c stays in no matter how fast i wanna go. i'll spray a 300 shot before i remove my a/c.
you're nuts. you're in mi too though, that helps live with that mod. anyone would have to be out of their f'in minds to do that in texas.
good luck w/your times tho, 52lbs might yield you some results.
Old Aug 20, 2004 | 02:33 PM
tomaSS's Avatar
You won't see anyone doing that in Vegas, unless you own lot's of Right Guard! How many pounds was the sway bar?
Old Aug 20, 2004 | 04:38 PM
Another_User's Avatar
I thought you were going to say you were on the Atkins diet. It doesn't matter where you lose it...the car or your ***....52 lbs is still a faster trap speed.
Old Aug 20, 2004 | 04:48 PM
Ferocity02's Avatar
How hard was removing the A/C? I never use it.
Old Aug 20, 2004 | 04:51 PM
hourang's Avatar
um yeah its like the middle of summer and its 61 degrees out right now
Old Aug 20, 2004 | 06:10 PM
Bad Blu Formula's Avatar
Dang, thats a lot of weight. The swaybar weighs about 5 pounds and isn't worth removing if you're looking to lose weight. It will help with weight transfer in letting your suspension travel farther. 52 pounds off the front of your car is the equivalant to 104 pounds because its off the front of the car. Expect alot of front end lift when at the track.
Old Aug 20, 2004 | 06:36 PM
DaleMX's Avatar
Now that the A/C is gone, you can run the heater inside the cab to help keep the engine cool and make even more power!
Old Aug 20, 2004 | 09:07 PM
mike c.'s Avatar
FEROCITY02-removing the ac was nothing. took about 40-45min and never even had to remove the radiator. i put everything on a scale to check weight.TOMASS-the sway was 10lbs w/3more lbs of brackets and such. i never use the air so having it was just wasted weight,and the summer in michigan has not been hot.(good race weather) humm....abs might be next. thanks, mike c.
Old Aug 20, 2004 | 11:02 PM
deviate42's Avatar
i might try that, i havent used AC since i bought my car........
Old Aug 20, 2004 | 11:33 PM
stevebSS's Avatar
No A/C in my car. I get hot I just drop the top
Old Aug 21, 2004 | 12:25 AM
LS1LT1's Avatar
Lightbulb
I knew it was more than just a mere 5 pounds...13+ pounds is CLEARLY worth it in my opinion, even without the weight/load transfer benefits thrown in.
Old Aug 21, 2004 | 01:29 AM
Matt D's Avatar
Retired Street Racer
so far i have removed the A/C, front and rear bumper supports, front sway bar, spare and jack, back seats, misc. small stuff like the horn, etc., and replaced the heavy *** leather front seats with light weight race seats...best mod you can do is weight reduction in my opinion...it's free...next is lightweight brakes, chrome moly suspension, speed inc. carpet, draglite wheels, and removing the airbags...ABS is only a few pounds, but every little bit helps.
Old Aug 21, 2004 | 02:15 AM
cyphur's Avatar
hahahaha i have a sunshield thingy you put in your winshield to block out the sun, AND i leave the windows cracked overnight, and my car STILL heats up past 100* during the day, easy. texas heat is no joke, and this summer has been mild LOL. i'll lose the back seats, ditch the airbags, lose the bumper supports, go for lightweight brakes, lightweight carpet, but never the a/c. i'll go on a liquid diet before that happens.
Old Aug 21, 2004 | 06:47 AM
jrp's Avatar
jrp
SN95 Director
my a/c is getting the boot when the new motor goes in, also got a tubular k-member and solid motor mounts
Old Aug 21, 2004 | 11:39 AM
tomaSS's Avatar
13 lbs. doesn't sound like a lot, but I guess it all adds up! I might remove the sway bar when I remove all the smog equipment with the header install.
Old Aug 21, 2004 | 04:31 PM
mike c.'s Avatar
ARE YOU GUYS READY FOR THIS? the 52lbs i took off my nose droped my e.t by 1.9 tenths. i ran almost .2 better with nothing but the weight reduction. my 60 foots were real close 1.72 to 1.70 and the weather was near the same 77 to 73deg. i'm going after k-members and fiber hood now.
Old Aug 21, 2004 | 04:34 PM
cyphur's Avatar
thats badass man....looks like i should invest more time into her long term diet then i thought....those results are impressive, especially for just 52lbs. very nice.
Old Aug 21, 2004 | 05:17 PM
Matt D's Avatar
get the PA RACING k-member...they are chrome moly...if you think those times are great, keep going with the weight reduction...bumper supports are heavy *** hell, and you don't need them
Old Aug 21, 2004 | 10:36 PM
JoeDirt's Avatar
whats involved in removing the "bumper supports" . ??
Ive removed my air system and it was 12lbs with a couple of heat sheilds.
Pass side bag was heavy , with the bracket it was around 17 lbs I beleive.
I need more non ghetto stuff to remove
