Drag Racing Tech
Will I ever see a decent 60ft???
Old Aug 21, 2004 | 04:45 PM
Got LS1?'s Avatar
Unhappy Will I ever see a decent 60ft???
Went to the track last night (VMP in dinwiddie, VA) and ran my recently installed 12-bolt with BFG DRs. I was expecting 1.8 or lower 60 ft times but was cutting consistent 2.0X to 1.9X (on the high side) I tried about every combo of launch I could think of. On stock tires I had to launch around 1700-2000 or I'd spin 'em, with the DR's I figured I could up that. Here's pretty much the combos I ran with:
DRs at 19 psi
launch at 2500, bad bog and slowest 60ft (about 2.2)
3500 and dropping clutch, seemed like a little spin. Did this with both turning over the tires and getting them smoking and same result.
Lowered DRs to 17 psi and adjusted rear KYB shocks two notches softer
4000, clutch drop, some spin....no better
3500, clutch drop....no better
Ran about 10 times total and nothing better than a 1.9X.
I have Lakewood boxed LCAs and ADJ Panhard rod, also the Edelbrock TQ arm.
I suck, track prep, non-adjustable TQ arm....what is holding me back from the 1.7-1.8 range?
Race weight was 3765, also stock clutch which seemed to hold pretty well.
I want to keep it as I would run on the street with the exception of the DRs. Have I reached my 60ft limit? In contrast my 60fts on Sumitomo HTR-Zs was in the 2.0X to 2.1X range.
Any inputs would be appreciated.
Old Aug 21, 2004 | 04:52 PM
SilverGhost's Avatar
Motorboater
i'd like to hear more about your burnouts...drag radials need to be HOT to work..
Old Aug 21, 2004 | 04:53 PM
Motorboater
oh and if you feel yoru were hooking..how was the clutch? if that stocker is slipping bad its not gonna pull through the sixty foot well.
Old Aug 21, 2004 | 07:07 PM
WILWAXU's Avatar
Dinwiddie is capable of some killer 60fts.. I went 1.88 on GSC's there. An numerous 1.5's after the converter and ET Streets.
IMO, if your going to drag race a 6spd, you need to step up to ET Streets at least. Is it possible to get a killer 60 on DR?.. sure, but it will be WAY too inconsistant to be any fun.
My car at VMP:
Old Aug 21, 2004 | 09:31 PM
Got LS1?'s Avatar
SilverGhost:
I don't have a line lock, so the best and only burn out I got was about 5-7 seconds, enough that white smoke was going past my window. Still cut a crappy 60ft. Every other time I tried it I'd kill the motor going from the clutch to brake. Clutch was solid, it has only a few thousand miles on it and I haven't smelled it burn yet (knock on wood).
WILWAXU
What would the benefits of ET Streets be with my 6-speed? Would they give me consistent 60ft's or will I just have a better chance of a decent 60ft every so often? What about a burn out without a line lock...possible?
Thanks for the replies.
Old Aug 21, 2004 | 10:19 PM
98TAauto's Avatar
benefits your be traction...
granted im a A4 but cam only I could only see 1.64's average with DR's. I usually saw 1.58-60's normally, but it just depended on track prep. I slapped on et streets and my worse 60ft was a 1.56 lol. 4 passes and the 60's were 1.55-56's. Like wilwaxu said, et streets will hook far more often than DR's. You probably have found that once DR's start spinning, you usually have to let out to get them to bite some. ET streets are always trying to bite since their sidewall is flexing. You have the 12bolt already so you have slim chance of breaking the rear. Maybe borry someone's and try and see how they work.
you can come race at our fbody/stang event at MIR on sept 18th also if you want. Should be some quick cars there
VMP is a very good track also.. one of my fav's
Old Aug 22, 2004 | 03:44 PM
gator's 99TA's Avatar
with a 6 speed the ONLY option unless you are a sick driver and are willing to kill clutches on a regular basis are et streets or better yet et drags. more consistency and MUCH more traction. for what you want and you have the rear (and assuming the clutch), you need a 26x10.50 et street minimum. you can get into the 1.6 60' easily as well as fun as hell 6000 rpm clutch dumps! good luck. drag radials on 6 speed cars are just not gonna get it done to the average driver and track.
Old Aug 22, 2004 | 05:19 PM
Got LS1?'s Avatar
Thanks all,
If I want to do better it looks like I will probably have to look at selling the DRs and getting some ET streets. Still a stock clutch in it, how long would it last? I'd only go to the track 2-3 times a year, if it last thru a few years of that I'm good, if it toasts on the first run I may just have to cut my losses and keep the DRs and hope for the best.
Old Aug 22, 2004 | 06:20 PM
Squintz Palladoris's Avatar
I am suprised that the clutch is still workin now. A better clutch will be a night n day difference. The 2-3 shift will be much better as well.
Brad
Old Aug 22, 2004 | 06:39 PM
Got LS1?'s Avatar
Brad
Yeah, I missed the 2-3 a few times. I'm sure the next mod is a clutch, but I really hate working on my car and having to trick my wife into thinking I need a new part. Don't get me wrong, I hate paying someone for something I can do myself even more so I do it, but I need a break after the rearend install. Stock clutch still feels solid on the street, hopefully it lasts me until I'm motivated again to start modding.
Old Aug 25, 2004 | 06:15 PM
ONGRNGO's Avatar
Hey I thought I would let you know how I launch at the track with my 6spd Camaro SS. I lower the Nitto DR's down to 15PSI cold, do a 10 second burn out so they are nice and hot, launch at about 3500 rpm and get very little spin and pulled off 8 runs between 1.83 to 1.86 60fts, But I have a Spec Stage 3 clutch also, but they are decent 60ft times for 17" Nitto DR's.
