Drag Racing Tech
BMR K Member: Lower frontend?
Old Jan 20, 2003 | 07:45 PM
frcefed98's Avatar
Default BMR K Member: Lower frontend?
My BMR K Member came in and I read in another post that it lowers the frontend 1-2in? I hope not because with my skinnies the formulas frontend is already way low.
Does it?
J
Old Jan 20, 2003 | 11:41 PM
SILVER BULLET's Avatar
Default Re: BMR K Member: Lower frontend?
I have a PA k member in the garage and noticed the same thing. With my ATI hoses that go to the intercoolers I definitely can't afford to loose more ground clearance. The BMR a-arms don't bolt up properly to the k member, so I am thinking I may have gotten the wrong k member(LT1 or something)
Old Jan 21, 2003 | 11:10 PM
12secondv6's Avatar
I run the pa racing mild steel drag k member, mild steel lower a arms and manual steering rack
These were all installed at the same time
The nose of my car did significantly drop, 1+ inches even though I lost 40+ pounds.
I still run stock springs and shocks.
I have HAL's sitting in my room.
I am told that once I install my HAL's I can raise the vehicle back up to a normal height
