What psi for Drags, Tubes?
As for pressure you are going to have to just play with them to find out what they like. I would start at about 13 cold, go make a pass and as soon as you get back measure them again they should be about 14 or so. if they spun outta the hole lower the pressure 1 psi, and make another pass. Keep this up until you are happy with the traction. You want to run the most pressure you can and still hook up. the more pressure you have in them the less rolling resistance you have . Remember a little spin is good, I usually shoot for about 7-10% spin.
As the pressure goes down, it will feel like the car is moving around on the top end of the track. This is just the wheels moving side to side in the sidewalls, believe me it will feel strange, what I tell my friends is watch out the hood of the car, if the car hood is staying in the middle of the track it is just the wheels moving, dont correct it because it will just make your car start darting side to side. Remember soft grip on the steering wheel if you need to adjust where the car is on the track soft smooth corrections.
I agree with Btl Feed. No one pressure for all. The track will tell you what it will handle.
David
Good Luck,
Daren
I'd like to know that too. I'm debating selling the 26x11.5x16 Et Streets and going to a 26x10x15 Et Drag hoping for more consistant 60's times especially on slick tracks.
