Drag Racing Tech
Torque Arm/LCA/bracket questions
Old Aug 30, 2004 | 07:59 PM
BLK02WS6's Avatar
Default Torque Arm/LCA/bracket questions
Is anyone running LCA relocation brackets on a non-lowered F-Body to change the instant center and increase bite? I was wondering how much they help on a non-lowered car.
I was also thinking of getting the Spohn sperical rod end LCA's to replace my poly's and a rod end to replace the poly in my Spohn torque arm. Anyone using the rod end versions of these?
I realize it will be much noisier, but don't care - I'll live with noise if it will bring my 60's down more. The car sees some street use, but mostly track. Any input would be appreciated.
Old Aug 31, 2004 | 06:15 AM
GeorgeC's Avatar
It seems that different cars will vary, but I always had great success with relocated LCA's on my old car... It was almost a night and day difference at the track, and I did do a good bit of experimenting with the suspension setup. The car was stock ride height...
Old Aug 31, 2004 | 10:28 AM
JeffT's Avatar
i run the lca relocation brackets on my non lowered car. Sorry, no before/after information though. I also run the rod end lca's and panhard bar. Just make sure the lca rodends are NOT teflon lined and you'll be ok. After a while you will beat the teflon out and they will rattle. My short times are nothing stellar but I'm consistently pulling bottom 1.4x's with a 6spd and 28x10.5 et drags.
Old Aug 31, 2004 | 10:43 AM
MIGHTYMOUSE's Avatar
hey blk02.. i have a spherical end for my spohn thats barely used.. i ordered poly and they sent spherical,.. then sent me the poly to replace.. pm me if you want to buy.
Old Aug 31, 2004 | 03:13 PM
BLK02WS6's Avatar
Thanks for the replies - any more?
JeffT - I would be very happy with bottom 1.4's!! The Spohn rod ends don't have the teflon in them - they are using the best QA1's you can buy, so I think they will hold up (not cheap, but you get what you pay for).
Mightymouse - PM sent.
