how to screw tires to rims?
Re: how to screw tires to rims?
every speed shop sells them .summit does also . its easy the inst. are on the back of the package. it tells what pilot hole to drill. eight per side with tires off rims, put tires on screw em in, dont i mean dont crank down on them they will break off...not to tight they will not back out and make sure you run tubes...
